Unable to set TV channels on dvd recorder since connected to Sky box
I have connected my Sony DVD recorder to a Sony TV and Sky box. However, when I try to do the Easy Setup, it appears to set the channels on the DVD recorder using Smartlink. Once the setup is complete, I am unable to see any of the TV channels on the DVD recorder which means I can't use it to record any TV programmes. I don't want to get a Sky+ box as I am only renting the house for 6 months. I'm not sure if I have everything connected OK or not or if there is something else I have to do in order to be able to use the DVD recorder.
  • Mary Ryan Feb 18, 2008
    The Sony DVD recorder model is RDR-HX525. There is nothing on the Sky box to indicate the make or model. It just says Sky Digibox.
  • Anonymous Mar 27, 2014
    I want to connect this machine in such a way that it would be able to record even when TV is switched off
    Genius:
  • 3,422 Answers
Please connect ariel to vcr then dvd then tv .scart(tv)on sky box to tv.scart(vcr)on digibox to vcr.vcr ariel out to dvd in,& dvd ariel out to tv. to record vcr video to dvd must set to av on dvd player. you should be all right with this.
If you still have problem connecting then Just refer THIS link and it will tell you everything as how to set it up step by step with the diagrams.
Goodluck...
Posted on Feb 18, 2008
    Genius:
  • 1,665 Answers
You have done wrong connections. You must follow carefully instructions are given at recorder's and sky box's user guide and do the interconnections correct.
If you have lost user guides of your set give their data to search if they can be found on web.
  • 689 Answers
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
  • ExpressFiX
    ExpressFiX Feb 18, 2008
    You get parallel connection from the Sky box to TV or you can use the alternate output. Can you please let me know the model of your DVR and Sky box (usually motorola models).
  • ExpressFiX
    if its skyDigibox you can get the instruction manual including the connection
    here is the link
    http://www.avs-con.net/Docs/digibox_user...
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
Hello! I have just purchased a LG DRT389H DVD recorder as I want to copy the programmes that I hv on my sky+ box. I have followed every instruction in the book but for some reason am just unable to do so....
Connect the sky box to the dvd with a scart lead,plug it into av2 on the dvd.When you want to record from the sky,select av2 on the dvd as your record channel.Check that the scart is fully in on the tv and the sky for sound problem.
Nov 15, 2009 | Televison & Video
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
How do i connect a dvd recorder. to my sky box and t.v
Take the main aerial into the dvd,then a flylead out of the dvd into the tv.Connect a scart lead into av1 onthe dvd and then into the tv.If you want to rec from sky connect scart lead from sky into av2 on the dvd,when you want to record select av2 on the dvd as this is the channel to record the sky on.Hope this helps
Sep 08, 2009 | Televison & Video
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
Connection Nightmare
try here in this forum http://radioandtelly.co.uk
they will give you some ideas t oconnection set up .
riz.
Nov 02, 2007 | Daewoo DVDRW11 DVD Recorder
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
Electro Med Services...
