Question about Lite On LVW-5005 DVD Recorder
Lite-on DDW-813s I actually have a yamada DVR-9000H which has the same drive and the same problems as I have seen asked everywhere. Any idea what Lite-on drive I could use to replace it?
  • Anonymous Mar 24, 2008
    i cant open the dvr door to insert a disc. HELP.
  • Optimxr Apr 21, 2008
    My 5005A was performing just fine, then it stopped ejecting! When I power up
    the drive makes some whirling sounds but it does not eject. This appears to be a OEM specific drive unlike the standard internal drives made by Lite-On.
    I believe I could get back to normal operation if I could just replace it.
  • 28 Answers
Open the drive (dont break it). Eject the tray, under the tray you should see a small belt drive. Replace the belt with a rubberband of approximatly the same size (a little smaller wont hurt). Re-assemble the drive and it should eject fine. Lite-On drives seem to go through these belts pretty quick, I have fixed hundreds this way. Never had one I fixed come back for the same problem.
Posted on Jan 13, 2009
I've got a Lite-on 5005. And I'm not using it any more. But I would like to use the converter, from "scart in" to "comp out", build in the 5005. The 5005 preforms a check at start-up whether the DVD/CD player is ok. Now I don't need the DVD/CD element, so is there a option to disable this check? So I can put the hole thing in a smaller box.
I hope is nothing more then using a jumper on the 40pins connector.
thank you, Tom
Posted on Jan 25, 2010
Throw it away and replace it with a newer recorder. those old liteon's had really bad compatability and recording quality
Posted on Oct 05, 2008
Lite-on DDW-813s Open DVD draw and you will find a belt drive that open’s the draw Replace the belt I used and ‘O’ ring, the problem is that the draw is not shutting correctly.
Posted on Sep 06, 2009
Where can i dowload the user manual
hello
i am the owner of a dvr-9300hx recorder and i need the driver can you send me have a probleme with it
thank you for your help
Jan 14, 2014 | Yamada DVR-9000H (80 GB) DVD Player / HDD...
Dvd/cd drive will not open. model ddw-813s
This is simple.
Take a long needle [should be somewat long]
Below the tray there is small hole.
Insert the needle/ pointed object through it, n press in by applying some pressure.
The tray will now come out
Thats all
Hope this helped.
Jan 09, 2010 | Computers & Internet
1. DVD DRAWER DIFFICULT TO OPEN OR CLOSE, GIVES MESSAGES LIKE INSERT DISC WHEN ITS ALREADY IN. 2.WILL NOT RECORD TO HARD DRIVE DVDS BURNT ON A PC, BUT HAPPILY PLAYS THEM. yamada DVR 9000H
Hi it sounds like you have condensation in the dvd unit.
Take the dvd out if you can,if not don`t worry.
Go to a warm room, plug dvd in to the mains and leave for 2-3 hours .Then try again...fingers crossed!
Dec 04, 2009 | Yamada DVX-6600 DVD Player
My player says it cannot read disc
run the cleaner Dusc maybe the lense is dirty.
plz rate this post as good as u can so we can help others
Feb 08, 2009 | Lite On LVW-5005 DVD Recorder
Error code
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} If you’re any good with computers, it’s a standard hard disk - you can take it out very easily, stick it in a PC, and format it. That should work OK. If you’re not any good with computers, maybe you know somebody who is? Apart from that, to take it out, you just open the case, disconnect a ribbon cable, a power cable (plugs for both just pull out) and 4 screws, then out it comes.
Alternatively, you could get a very big hammer and smash it to pieces, which is what I feel like doing with mine...
Roger
Sep 03, 2008 | Yamada DVX-6600 DVD Player
DVD-RW Unit Replacement
Lite-On DDW-813S mounted in thin sheet aluminum (probably for RF interference reduction.)
http://forums.afterdawn.com/thread_view.cfm/374328
Mar 15, 2008 | Radio Shack Accurian ADR-3223
Lite-On LVW-5005 (DDW-813s)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A4P, it work perfectly, good as new. but you have to make some changes to fix it to the place
Oct 01, 2007 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
2,720 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
