Question about Freezers
Freezer temp display beeping and going through different temps rapidly!
Fridge and freezer appear to be working ok, I mean the fridge is cool and the freezer stuff is frozen. The machine is quiet and not constantly running, all seems fine but intermittently freezer temp display starts flashing and beeping as it goes through several series of temp changes from -17 to -25 in very rapid succession. It behaves as though someone were pressing the freezer button to change the temp setting ( only I promise you, no one is near the machine)!
Any ideas as to what is going on?
  • 1 more comment
  • alicemvh Feb 17, 2008
    The model is a Samsung SL36WJ1/XEU Fridge/Freezer and is about 6 years old.
    I think it may be a switch problem but I took off obvious screws around the panel but the cover still seemed to be attached. Any help with getting front panel off so as I can get to the switches?
    Also the intermittent nature of the problem concerns me. I understand how a switch might stick on after you've handled it but this is a switch which is rarely if ever used. It is used to set the freezer temp and I have always used the ECO switch which maintains the temp at -17.
    I have also emptied and cleaned out the freezer and it doesn't seem to have affected anything.
    The freezer is maintained fairly full but not overly.
    Any help really appreciated, thanks
  • Anonymous Nov 18, 2008
    i have exactly the same problem - dit the suggestion of a faulty temp control switch cure it?
  • Gary Davd
    Gary Davd May 11, 2010
    PLZ post the model Number from the tag inside the ref section so we can help
  • 417 Answers
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Posted on Feb 16, 2008
I had this same problem exactly, I took the controle panel off and disconneted everything, took out the circuit boards and examined them and all looked fine, no dry joints or whiskering. However the connecting plastic connector at the end of the panel that supports the Power switch was broken, cannot think how, I honestlty think they shipped it like that!
I cut a long wine cork and positined that to ensure the circuit board was held firmly that end and re-assembeled evrything and plugged the system in --nothing!
After a week of reseraching and making up my mind what to buy to replace it I idly pressed the power button as I passed, as i left the kitchen i heard the unmistakeable Samsung Beep! The damn tyhing is working and looks fine now, it has been for 24 hours but before I put evrything back in I will wait a bit longer!
So, you could try same as me?
I am suspicious of an underlying issue, certainly chek the ventilation is good, and maybe get a service call to check the gassing>?
JT
Posted on Jun 30, 2011
Frigidaire refrigerator compressor overheated when I left the door opne.
the motor of the compressor may have tripped on overload protection. Allow it to cool down and then unplug the fridge then plug it back in and try to run it. It should run. Be advised that the condenser coils underneath need to be clean. You should have a strong person tilt the empty fridge while you vacuum and clean all the dust and lint off the coils. Be gentle as these coils are fragile and are easily damaged. Hope this helps.
Mar 26, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
I don't have the model number. Fridge/freezer five years old with an electronic control panel on the freezer door. Freezer temp not showing, nor can it be adjusted. Freezer temp lowering, but appears to be...
Well, its good that it is still cooling, however since you cannot adjust the temps, you do still have a problem, and one that may include the unit fails to cool properly.
Oct 04, 2010 | Whirlpool Freezers
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
Freezers Logo
546 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
