Philips DVDR3570H for multiregional playing
I recently bought the DVDR3570H from Singapore. I live in UK and after some unrelated issues just set it up again and now cannot play DVDs for my region. Can you tell me how to re-set it as it did play them before?
Thanks,
Dominic
  • cherylbarret Aug 06, 2008
    I have tried your unlock process - however it doesn't seem to be working for me :(
  • fecheyr Aug 10, 2008
    I bought one myself one yesterday (aug 08) and the trick did not work. new software?
Hi Dominic,
here is good news for you.
THE philips DVDR3570H CAN BE MADE MULTIREGIONAL .FIRST OF ALL ON THE SET. NEXT REMOVE ANY DISK ON TRAY. OFF THE UNIT AND ON AGAIN.NOW CAREFULLY DO THE FOLLOWING. PRESS HOME,THEN PRESS PLAY/PAUSE. TYPE THE NUMBER 159121212005255 AND PRESS PLAY/PAUSE. OFF THE UNIT AND ON. NOW THE UNIT IS MULTIREGIONAL. i AM A 100% SATISFIED CUSTOMER. THANKS TO PHILIPS.
DR SAJEEV BHASKAR.
Posted on May 11, 2008
Hey.. just want to say thanks to Sajeev.. worked a treat on mine.. upgraded the software to 3.06 and of course it reset regions.. it definitely works.. I just did it, but you MUST follow the routine. Turn on using front panel.. wait for it to boot up to LIVE TV.. then push HOME, then press Play/Pause, then enter the numbers in quick succession.. if you have done everything right it will show no "x" on top right of display.. press Play/Pause again, then switch off.. PERFECT! I have my region free player back.. sorted! Rob McL in New Zealand
Posted on May 21, 2009
Do it quickly. It will work.
Firmware version 3.04 i have
Posted on Nov 18, 2008
I have just tried this out & at the thrid attempt it works, HOWEVER you HAVE to put the code in immediately you press play/pause and don't waste time doing it. You have about 3 seconds to get the code in before 'BROWSER' appears and it wont take the code. If you are to slow, just start again until you get all the number in. I have firmware V3.06
Posted on Jan 12, 2010
I HAVE A DVDR3570H, FIRMWARE 1.13 . HOW CAN I UPGRADING?
Posted on Apr 26, 2011
This hack does not work
Posted on Nov 17, 2008
  • aabotaiban Nov 17, 2008
    Just wanted too add that my framware version was 1.43 and i upgraded it to the latest according to philips support site. the hack didn't work before nor after upgrade
Playing DVDs
NoThese days most of the companies are producing Region 0/ALL DVDs If you can get them OR buy a dual region DVD i.e. Region 2/4 which can play on both the regions. Most of the DVDs produced in India are multiregions. Choice is yours now
Apr 17, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVDR3570h is stuck in standby, cannot turn on
I had this problem, it was solved by reformatting the hard-drive.
NOTE: if you do this, all settings and all that is saved on the harddrive is lost. But seeing that you can't start it anyway, that is acceptable, right? :)
Anyway, here's how you do it, according to Philips support:
  1. Pull out the power cord from the socket.
  2. Press and hold PREV and STOP (i.e. left and down) on the front panel.
  3. Plug the power cord into the socket again.
  4. Wait until the front panel says "FMT KEY" to let go of the buttons. Wait for it to finish formatting, upon which you will get "-- --" on the panel.
Restart the box and you should now end up at a screen asking you to set the language for the box, as if being started for the first time ever.
Also of note: if you want to restore the firmware to factory settings, Philips support told me to pull the cord, press and hold the STANDBY button, and plug it back in again. For the looping problem though, I didn't need that.
Mar 15, 2009 | Philips DVDR3576H DVD Recorder
Error, remove disc, turn power off
In Singapore, your region is considered "Asia." The simplest way to play Wii games on a Wii from a different region was using Datel's Freeloader disc, but unfortunately Nintendo has patched their firmware blocking the use of this. There are other ways to modify your console to play games from other regions, but all carry a high pricetag and a great deal of risk, and Nintendo can patch the firmware to detect your modification and stop your system from working. You might consider importing a Wii from the UK using Play-Asia.com or a similar retailer. Best of luck!
Jan 04, 2009 | Nintendo Wii Console
Dvdr3570H unlock region codes
I have just tryed and it works with one difference as follows:-
1. Turn on the player from the front panel (without a disc inserted)
2. Press" DISK " on remote and ensure Hard Disk is highlighted
3. Press PLAY
4. Enter 159 121 212 005 255
5. Press PLAY
6. Turn the player off
Sep 07, 2008 | Philips DVDR3575H/37
Philips DVDR3570H/05 constantly looping on startup
Apr 09, 2008 | Televison & Video
DVD region code lock unlocking on PS3
http://blog.us.playstation.com/?s=firmware+update&x=13&y=2
this is a link to a blog for firmware update.
I don't know if this will solve the problem, but there are people on that site who may be able to.
Mar 16, 2008 | Sony Playstation 3 (PS3) Console
PS3 80gb from Singapore will not play ps2 games Wrong region displayed
I,m pretty sure that the region settings on PS3s are factory set.
Your only option is to buy japanese games, or NTSJ.
I,d try to re-sell it back to someone in Singapore or Japan, and buy a UK Version.
Mike @ Compurepair.
Feb 22, 2008 | Sony Playstation 3 (PS3) Console
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
Televison & Video Logo
1,498 people viewed this question
Top Televison & Video Experts
