Question about Canon BubbleJet i560 InkJet Printer
Cleaning ink tank
I think I found a solution to 3100 but I particularly want to know about cleaning the ink tank and sponges incorporated
    Master:
  • 619 Answers
Hi , Just look for used injection cylinder wear a rubberized gloves , suck with cylinder the waste ink put into clean container ,if you have sponges available try to replace it .
Posted on Feb 16, 2008
  • Canon Master
  • 19,396 Answers
You need to open the printer, remove the waste tank and sponge, changing sponge and cleaning tank with water and then solvent solution. do it in your bathroom as its gonna be a dirty operation. I think in your printer the tank is located at right hand corner, watching the printer from front side
cheers
  • Ginko
    Ginko Feb 17, 2008
    "thanks for trying" is a negative rating!. was my solution completely unhelpful? I think I said same things as my collegue!Thanks.
SOURCE:
Unable to clean cartrigde
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Jul 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Need to empty used ink tank on canon i70
Hi rweber3
It take it you meant that you have to replace the cartridge ?
Simply open up the top cover and take out the old ink cartridge ( normally clips in and out ) and replace with the new.
If you have any further queries , feel free to post us another thread.
Thanks for using Fixya !
Apr 29, 2008 | Office Equipment & Supplies
Brother MFC-465CN printer. Need a fix for error 46.
Jul 09, 2010 | Brother MFC-465CN InkJet Printer
I think i found the actual ink spong (waste ink near full). Right side of Cannon pixma mp 780 close to center track ink thing runs back and forht on!) . Not taking it out but my logic here was if i found...
That is the ink sponge that you found. To clean it you just soak out the ink with a paper towel or washcloth like you have. You can also remove it and run it under hot water if you would like. It will just lift out of the cradle that it is in.
Good Luck
May 02, 2010 | Office Equipment & Supplies
Error message: the ink tank is full. Where is the ink tank and how do I empty it?
Please specify which printer? You have to reset the waste ink level in the printer & Need to clean the sponge/tank in the printer.
Apr 28, 2008 | Office Equipment & Supplies
Printer is printing everything in pink
more details please:
manufacturer
model number
if it's an inkjet, run any maintenance procedures like cleaning heads, take out each cartridge, take paper towel wet with warm water and touch nozzles gently to remove any dried ink.
Apr 07, 2008 | Canon Pixma MP950 All-In-One InkJet...
Ink waste Absorber
you are correct about the waste ink tank,did you check the pipe (if any)which use to carry the ink to waste tank,if it is clogged than also the problem will arise.
Mar 31, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon iP2000 Waste Ink Absorber - where is it for washing and replacing?
I found it under my ink cartridges in my Canon iP2000 printer. Trying to losten it for cleaning, it came out in my hand, I washed it and replaced it with a tiny amount of glue. After resetting the program, it is working again.
Feb 11, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA MP830 All in One - A600 error
Here’s what I found.
There is a sponge to the right as stated but right next to that is a white plastic arm assembly with a spring attached to it.
It was the white plastic assembly arm that was stuck and not fully retracted. I tried to move it back and forth and then (pingk) it fully retracted. I powered on the printer leaving the ink caddy to the left and as it was cycling I could see the plastic arm was covered with dried ink. I powered it off and moved the ink caddie to the left again and powered it on again. As it cycled I pulled the power plug leaving the assembly fully exposed. Grabbed some paper towel and put some alcohol on it and cleaned the dried ink off as best I could. I left the caddie to the left as I powered it up to see the assembly work
The printer is working again
Jan 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
365 people viewed this question
Clive
Clive
old marine
old marine
