Question about Health & Beauty
HOW DO I CHANGE BLADES ON MY TRIMMER?
I WANT TO CHANGE TO THE SMALLER BLADE ON MY TRIMMER BUT HAVE NO CLUE HOW TO DO THIS. PLEASE HELP!
  • mike king May 11, 2010
    What brand and model do you have?
    action mike
Braun 3000 series 3770.
Posted on Nov 03, 2008
HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
Nov 10, 2011 | Wahl 9854400 Hair Trimmer
How do I put the blades back in my model 059750 005 000 trimmer
I have the same model. Actually, they're quite old. If you don't have replacement blades already, you can find them at Sally Beauty Supply ( sallybeauty.com for a location near you ) for about $20 for this model. The replacement blade may not be available online, but my local store has it available for purchase. You may find it available at your local beauty supply.
Remove the two screws that hold the 2-piece blades in place. Remove the blades and take note of how they are situated together. Both have flat sides that slide together where the teeth meet. Your replacement blades should be arranged in the same manner when you put them back on the trimmer. First place the smaller blade onto the clip. This is best done by aligning one of the diamond shaped hole with one of the flat prongs, then pushing the balde towards the side to help snap the other prong into the other diamond shaped hole. Once this is securely in place put the larger blade on so that the smooth surfaces touch each other and the holes for the screws are lined up. Replace the screws securely but do not tighten it. Do the same with the second screw. You should just barely be able to slide the larger blade around with some effort. You will need to do this to properly align the blades together. The teeth of both blades should never meet at the tip. The smaller blade should be about 1/16 - 1/8 of an inch away from the tip of the larger blade and should be evenly spaced all the way across the width of the blade. If you have this set properly, go ahead and tighten one of the screws. Check the spacing of the blades again to ensure they have not moved. If they have, you just need to slightly loosen the one tight screw and re-adjust. Tighten the screw back down. If all is aligned propperly, you should be able to tighten the second screw without any problems. Don't forget to lubricate the blades with the proper oil. Check you local beauty supply store if you need oil. That's it. They are now ready to trim.
Dec 06, 2010 | Health & Beauty
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
Does the Wahl Model AC Trimmer have an adjustment for the blades? There is only a plastic insert between the blades
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Feb 22, 2010 | Wahl AC Trimmer Hair Trimmer
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
Dont know how to install blade
on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
Oct 07, 2009 | Andis 01690 Hair Trimmer
How do I put my shaver back together after I replaced the blades?
For Remington clippers, the smaller blade has a groove which matches a beveled edge on the trimmer body. Line it up, align the larger blade to its screw holes, insert and fasten screws until tight, and you're good to go. Oh yeah, and try to center the small blade.
Mar 12, 2009 | Health & Beauty
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Health & Beauty Logo
939 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
