Question about D-Link DCS-900W Network Camera
D-link DSC-900w problem
Hello
I am not able to connect in wireless mode, server is taking too long time to connect,if I connect a cat5 cable it is working fine
Kindly help me
  • technopodge Nov 08, 2008
    I'm having the same problem with the DCS-900W. Works great when hardwired, but cant get it to work wireless. Was curious if you found a fix?
  • endure Nov 17, 2008
    I have been wrestling with this problem for a while as well. I don't think it's a hardware problem as my brother in law has the same problem with his now. It's too bad that D-Link has discontinued updating firmware for this camera.
    Any ideas on how to test if this is a hardware problem?
    Problem Solver:
  • 4 Answers
I've had similar problems with 900's. Problem is, they have too short of a range. If you sit the camera (wireless) beside your router, you work fine. Separate it, no connection. They sell several models of antenna extenders for D-Link models including a huge master antenna, if you have a D-Link router. That has all my 900's working.
Posted on Feb 03, 2010
Problem:HP 336044-B21 8-Port KVM Switch do not seems to function properly, green light is not coming, sometime blinking, rack monitor do not show any signal coming from server, although the cable from...
You may have a bad ethernet cable. I would try the easy thing first and just go to Best Buy, Amazon etc... and purchase a new RJ45 CAT5 or CAT6 ethernet cable. Since you are receiving an orange light it is indicating that the port is not active. Also check the cable make sure its seated properly at both ends even with a new cable. Cheers! Hope it helps! J the Guru.
Oct 16, 2017 | HP (336044-B21) 8-port KVM Switch
Getting 169.254...
possibly cat5 cable problem or your DWL - 2100AP is only on wireless mode.
please check and put on mixed mode also.
Mar 08, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
How to configure the two wifi router
Are you trying to cascade two wireless routers? If yes, here's how:
1. First make sure that the first router (will serve as the server router) should be working. And then get the IP address of the server router.
2. Connect a CAT5 cable from the WAN port of the server router and the other end of the CAT5 cable should be connected to any of the LAN ports of the client router (which is the second router).
3. Then connect a computer directly to the client router and access its WEB UI.
4. Disable the DHCP server capability of the client router and set a static IP on the client router and make sure that it has the same IP range as the server router so that they would communicate.
5. After making sure that the two routers are on the same IP range, connect a computer to the server router and then ping the IP of the client router. Once you can ping it, then it should work.
If you're having a trouble with the setup or should you wish to have more information about the router, then refer to the router's user manual for necessary information.
Good luck and have a great day!
Feb 09, 2010 | Linksys Computers & Internet
Linksys wireless print server WPS54G - wireles network problem
access your router and go to wi fi settings check is it enabled if not enabled it.
Also check its netwrok settings like dhcp , ip addreses , subnet mask gateway.
Also check in your network that in gateway is always your linksys ip.
Let me know .
Jul 29, 2009 | Linksys Wireless-G WPS54G Print Server
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
High ping
Question, why are you using so many different routers? Sounds like you are causing a bottleneck in the network.
This is how I have my network.
Modem ---- PFSENSE Firewall (currently my DHCP Server) ------- Cisco Switch ------ Patch Panel ------- out to my Servers, computers and one wireless router. See only one machine is managing my IP addresses.
Buy a patch panel and run wireing to all the locations in the house or just run wireless.
Mar 31, 2009 | Linksys BEFW11S4 802.11b Wireless...
My internal wireless adapters will not connect to WPN284 wireless
Make sure the default gateways and DNS servers options for both wifis point to your wifi router
Mar 30, 2009 | NetGear RangeMax WPN824 Router
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Signifcant delay when printing
Your post does not mention all IP addresses in use, and which devices use wireless. That information would be helpful.
Is it possible that you are getting an IP address from a router for your internet access, then when you try to talk to your print server it may be trying to assign an ip address too.
(Sometimes a wired computer also has wireless enabled, which can cause an issue when one ip address has already been received on the wired connection and a wireless connection is also trying to connect.)
Mar 29, 2008 | NetGear PS121 Print Server
D-Link DCS-900W Network Camera Logo
430 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
