Question about Philips Recorder DVD-R72
Pscan Hi, When I turn on my dvd player the picture is like divided in to two parts and a big yellow sign on the tv says pscan... Can you please help me;)
Hi ! There is a switch at the back of the DVD which controls the pscan. just turn it off.
Posted on May 13, 2008
It was kind of silly... There was a button on the remote control called int./Pscan when I pressed it the problem was fixed...
Posted on Feb 17, 2008
3 Suggested Answers
SOURCE: memorex dvd player pscan split screen
thank you!!! it worked!!!
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: Bad DVD picture
please reset the factory seetings in uer dvd player, throgh menu button on uer remote. Firstly open uer tray and after take rhe menu and select factory reset, and reset it,
Posted on Apr 23, 2009
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
PSCAN warning and screen is split in two
hotpoint first edition hvl211 has 3 flashing lights how do u stop this is there a reset you can do
Jan 05, 2010 | Acoustic Solutions Audio Players &...
The dvd player displays a big yellow box in the middle of the screen with PSCAN with an exclamation point above it. Also the screen is showing the right side with a wide split between them. This is the...
I found the manual for this dvd player online. There is a switch on the back of the player. PSCAN is Progressive Scan. Some TV's are not compatible with this function so the switch must be turned off. This worked and I was watching a dvd last night!
Nov 03, 2009 | Memorex MVD2042 DVD Player
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 25, 2008 | Memorex Progressive Scan DVD Player...
AIM DVD PLAYER
there is a big orange sign that say PSCAN on a split screen How can i fix this
Nov 24, 2007 | Televison & Video
Divided picture on Protron PD-800 DVD/CD/CD-R PLAYER
Hi Alberto,
The split screen (identical display left & right) indicates that your DVD is on Progressive Scan.
P scan refers to progressive scanning mode and is not an indication of something broken but rather is a feature. What you can do is look over your remote and check if it's got a PS or PScan button. Pressing the button should revert to the single display. If there is no such button, pls check your menu or settings and should be there somewhere. At other times, there is a small hard switch at the rear (or front) of the player itself just for this purpose.
On your concern for no color, determine the color system of the disc you're playing, the setting of your DVD player as well as the color system of your TV. They should be the same. The 3 systems are NTSC, PAl and SECAM.
Hope this be of some help/idea. Pls post back should you have other concerns.
Nov 11, 2007 | Spectroniq PD-1100 DVD Player
Split screen
That is it thank you sooooooo much. I spent three hours flicking buttons and it is a stupid switch on the back!!!!!
Aug 26, 2007 | RCA DRC6355N DVD Player/VCR
Televison & Video Logo
385 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
