Question about Jabra BT125 Headset
Not able to connect Jabra BT 125 to Laptop
My JB125 is working with Blackberry & while i am trying to configure to Vista loaded laptop, it is asking for Driver which i am not able to get from net.Pl. suggest.
  • 6 more comments
  • dunmorogh Feb 28, 2008
    i bought a jabra bt125 but now how do you connect it to the laptop? i was thinking of using it for internet phone calls such as skype. i used a usb cable that converts from the mini usb port on the jabra to the standard usb port on the laptop, but the laptop did not detect the bluetooth device. any help/suggestions are greatly appreciated!!! thanks!!!
  • Anonymous Mar 12, 2008
    i hav same problem
  • Anonymous Mar 31, 2008
    Exact same problem: Vista on PC, jabra connects, but driver is required...no driver on www.jabra.com
  • jazzstudio Mar 31, 2008
    Exact same problem: Vista PC, jabra is recognized and connected, BUT driver required for installation. No driver at www.jabra.com
  • sweetshake Apr 06, 2008
    i need the driver for mac computers
  • lostindamaze Apr 07, 2008
    I have the same problem. It works on my PPC6700, but not on my laptop. I tried the "solution" on here with the passkey & that didn't work either. It still says I need a driver for it.
  • Anonymous Feb 17, 2009
    got a laptop but it doesnt show up and where to you find the key code???
  • keyuoo7 Mar 28, 2009
    i can connect to my computer but it say that i need to install the driver i dont have the drivers so it tells me to use a disk i dident get one of these either and when i look for the drivers via the internet it wont locate the drivers
    if anyone knows where to get the drivers for the jabra BT 125 plz list the site
Correction to the above note...
You can connect your Jabra 125 to your computer's audio output and listen to music via the ear piece. You need to make the adjustments in the control pannel. Set the audio/sound output to the blue tooth. You also need to sync the earpiece to the pc via a dongle or bluetooth adapter on the pc. Works great...
Jimmy
www.CLSONLINE.org
Posted on Jul 05, 2008
Hi Guys,, I have the solution:
1) full charge your Bluetooth device.
2) press the run button and hold it for 7 sec.. till light become illuminated.
3) go to your Bluetooth device in your computer in the menu:
A) Devices.
B) Add.
C) mark in box says “My device is set up..." Then press next.
searching for Bluetooth devices. Choice your device. then press next.
then here this is very Important step.. keep in your mind all Bluetooth devices comes with "0000" this digit password.
choice Use the passkey found in the documentation: and put it "0000".
then press next.
you will saw it connecting...
then you will saw the installation steps working normally.
after that you will saw that msg (( Completing the add Bluetooth Device wizard)).
finally press finish.
From menu go to Audio:
you will see all your Bluetooth devices choice your headset Bluetooth and press connect.
and enjoy with your easily live.
Regards Dody From Saudi Arabia.
Kindly If you need any assistance don’t hesitate to contact me.
Email: bently_70@hotmail.com
Posted on Aug 08, 2008
I have one problem here. I can connect my Jabra BT125 on my laptop, but when i choose to switch my audio outpout to my Jabra, soud still comes out from my computer.
Posted on Aug 14, 2009
Your going to need a bluetooth dongle, or bluetooth on your computer.
Posted on Mar 18, 2008
AFAIK, the mini usb port is just for charging. press the white button and hold until light is steady, then device is discoverable. Pass code is 0000.
Posted on Mar 11, 2008
0000 pairing number not working with my blackberry
you can try 9999 / 1234 / 4321 also make sure that the Blackberry is set to be discoverable if not then the Jabra BT headset will really not detect it.
Jul 04, 2011 | Jabra BT2050 Bluetooth Headset
How to listen music on Jabra BT 125 with samsung GT-C6112
The Jabra headset when connected to phone will only do voice calls.Will have to get a bluetooth headset that will play music.
Oct 20, 2010 | Jabra BT125 Headset
I HAVE A JABRA BT 2070 I WONT PAIR WITH MY BLACKBERRY 8520 EVEN WHEN I PT PASS CODE IN PLEASE HELP ME WITH THIS ISSUE
Try putting in 1111. It still will not engage. But after you do this it will reset. Then put the 0000 in and you will be connected.
Oct 08, 2010 | Jabra Bluetooth Headset - BT2070
Looking for a replacemnt ear hook for Jabra BT 125
hello. any one of these dealers should be able to assist you. http://www.jabra.com/NA-US/WhereToBuy/pages/Default.aspx
please mark my answer as very helpful. thanks. Joe
Mar 25, 2010 | Jabra BT125 Headset
I lost the instructions. I want to pair my Jabra bt125 with my motorola razr
1. I have the Jabra 125. You can get the manual at www.jabra.com if you have a different one.
2. Turn off your phone. Power off. The order of powering on devices is the key.
3. Press and hold your Jabra power button until it's glowing blue (not flashing blue light--but constantly on)
4. Then turn on your phone...and look for wireless devices in your phone menu.
5. Make sure you have bluetooth turned on.
6. the phone will find the Jabra, and then will ask to pair with it. passcode is 0000.
7. That's it.
Again, the key is the order of turning on devices.
Thanks.
Jun 05, 2009 | Jabra BT125 Headset
Jabra BT620s pairs to laptop but unable to switch sound output.
I had this same problem with my sony vaio (vista). But at first for me, after BT enabled the device, I couldnt find it in the device manager. I cycled on and off the headset a couple of times and once my vaio began to automatically connect the device, I was able to locate it in the device manager. Next, I went through the contol panel, hardware/sound, "manage audio devices". Here the bluetooth headset was located. After sucessfully testing the headset, I set it to default. Now whenever I fire up the headset, I have total mobile sound...awesome
Jan 05, 2009 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Jabra Bt 620s bluetooth stereo headset
please try by reinstalling the drivers
Mar 18, 2008 | HP Compaq nx6310 Notebook
Jabra BT125 Headset Logo
7,051 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
