Question about HTC Touch P3450 Smartphone
Cracked front cover on HTC Touch
I have a HTC Touch. The cover cracked in line with the screw holes. It looks like a manufacturing/Design defect. Anyone else had any similar issues.
  • 1 more comment
  • fulcr Feb 21, 2008
    I am having the exact same problem on an HTC touch right by the volume lever and the provider refuses to warranty as they say it was intentional damage!
  • Anonymous Nov 08, 2008
    Same Thing here...
  • YellowTek Dec 16, 2008
    I have the same problem! I have took the phone to the htc because I have a problem with the glass. And they told me that the phone it is ckacked in the up and left side of the phone where the volume button is. What is happening????
  • 846 Answers
HTC will help you with this because it is so new. However if you dropped it (etc.) and if apple doesn't replace it for you, You can get the part at HTC Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
Posted on Mar 06, 2011
How do i check the pump
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Feb 25, 2015 | Reddy Heating & Cooling
Are all htc one replacement screens interchangable?
HTC pledges to replace your phone's cracked screen for free
In a generous move, HTC will resupply unlucky handset owners saddled with damaged displays free of charge.
http://www.cnet.com/news/htc-pledges-to-replace-your-phones-cracked-screen-for-free/
Has the screen on your HTC smashed, cracked or broken? At Geek Squad, we're manufacturer approved to carry out HTC screen repair, so whatever problem you have with your glass or LED, we can sort it. An HTC screen repair can be done for a phone in and out of warranty.
http://www.geeksquad.co.uk/services/repairs/mobile-phone/htc/screen-repair
Apr 14, 2014 | HTC Desire Cell Phone
Front bumper guard pulled loose on curb. Missing plastic push pins. One corner cracked slightly. Looks like it can be snapped back into place. Any suggestions?
New push pins and drill a couple hole on both sides of crack to install zip ties this will hold or you need to replace the cracked piece (bumper cover etc)
Mar 26, 2014 | 2004 Chrysler Sebring
Burns for one or two minutes then stops. also giving a code 3
or
Jan 30, 2014 | Reddy Heater-70,000 BTU Kerosene w/T'stat
The screen is cracked on my htc 4g my touch. Can u fix it?
Once a screen is cracked there is no other way than replacing the screen. We can help you out only in getting the screen replaced. For that you need a watchmaker and a new screen.
Mar 26, 2011 | HTC Touch P3450 Smartphone
How to replace a cracked lcd Screen for the htc Touch gsm
You will get cheap lcd from ebay.com
or anything else let me know
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | HTC Touch P3450 Smartphone
Cracked screen
Hi
The warranty covers manufacturing defects and such, camera stops working completely etc, cracked screen is not one of those things.
You must have dropped your purse or something must have pressed on the screen and caused it to crack.
I think they will charge you for a new screen.
Sep 10, 2009 | Nikon Coolpix S210 Digital Camera
Cracked head unit
Yes warranty will cover manufacturer defect.
Sometimes even if it is out of warranty it is worth it to call the company because of a possible design flaw.
hope this helps
Mar 25, 2009 | Home
Cannot hear the incoming voice
While phone is on pull battery and see if it resets software, check your memory available on phone.
Jan 02, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
182 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
