Question about Uniden Cordless Phone
Caller id not coming
My phone is not giving cid
I had this same problem. Unidens troubleshooting was terrible. I finally figured out what the problem was though. In the address book on the phone it only holds 100 phone numbers. If it is full, and someone calls it will not store the number. Erase some of the entries and see if it will work then. It needs a certain amount of space to hold the number. Hope this fix will work.
Posted on Jun 23, 2008
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
I installed a caller id card in my kx-ta624 panasonic system in my home. The manual I have describes kx-t7030 phones with a caller id indication button but my phones kx-t7730 do not have a button and so I...
You get to program it :-)
In the User's manual section 2-2 there's an alpabetic index for Caller-ID. It requires 2 buttons, a CID-Indicator and a CID-Select button. We usually put them as the top 2 buttons in a 773x series phone, but you'll have to pick 2 adjacent or similar CO buttons. You label them CID-I and CID-S. Then you program them for either 96 and 97 or 6 and 7. You also have to tell the programming that you are setting up the common CID if you use 96&7.
Dec 12, 2010 | Panasonic KX-T7730 Corded Phone
M7310 + Caller ID
You need CID service from teoco, Caller ID capable circuit packs in your Norstar system and 2 parameters turned on in programming under "terminals a & sets" for each extension. Also the CID will only auto display on sets that have the ringing turned on for that line. (you can also program a display button..feature-811). I doubt it is the software version but to display it go into programming and step down through the menu from 'Terminals&Sets' 10 items to 'Maintenance' and press 'show' then show again at 'System Version' this will give you a display like "SP: 30DHC04 NAT". Hope this helps. Bill C. We also do remote programming on Nortel CICS and MICS so equipped
Mar 15, 2010 | NorStar M7310 Corded Phone
My caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Dec 04, 2009 | Panasonic KX-T7731 Corded Phone
Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Nov 11, 2009 | Panasonic KX-T7420 Corded Phone
On my model 8885 uniden phone, when I try to store a # the screen say's memory full. I only have two numbers stored. help
These phones use a "Shared" memory, the CID information and the Phone book information share the same memory chip. If you clean out the caller ID data you should be able to load more numbers in the phone book. Since you have an 8885 I am assuming you have TCX800 or TCX905 handset(s), to clear the CID memory, Follow these steps:
Deleting Information from the Caller ID List
1) When the phone is in standby mode, view the Caller ID
information to be deleted (see "Viewing the Caller ID
List" on page 50).
2) Press the DELETE soft key. De let e C all er ID appears.
3) Press volume up/down to choose Yes.
4) Press the OK soft key. You will hear a confirmation tone.
To delete all the CID information follow these steps:
Deleting all Caller ID names/numbers
1) When the phone is in standby mode, press cid.
Press the DELETE soft key. De let e A ll? appears.
2) Press volume up/down to choose Y es.
3) Press the OK soft key. You will hear a confirmation tone
Mar 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden Power Max 5.8
try to give ur phone a soft reset.
to perform that try menu/settings
or any soft reset button in the phone bottom or back
best regrads
if not help tell me.
plz do rate this poste
Sep 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
Caller ID does not work
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Mar 06, 2008 | Vtech ia5864 Cordless Phone
Uniden Cordless Phone Logo
256 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
