You need a new clutch spring.
http://www.thesupplynet.com/ScanSnap-S510-c4224.html
See chapter 6.
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/s510m_get-started-guide.pdf
what is clutch spring?
Go tohttp://www.thesupplynet.com/ScanSnap-S51...
There is a picture of the clutch spring. It is part# PA03360-Y106
I think it's a good idea to also get a new Gear part# PA03360-Y104
I kept having to replace my clutch springs, then I replaced the Gear and have not had a problem since.
Maybe also should get "Pick Gear" PA03586-Y061, as well as "Gear" PA03360-Y104, as I'm not sure I remember which one I replaced, so to be safe replace both.
I have the same issue. I replaced the clutch spring - still have the issue.
I purchased both of the gears but neither are the one on the shaft next to the clutch spring. All the gears I can see have all of their teeth.
