Audio can't be heard
Audio so low I can't hear directions
  • Anonymous Mar 23, 2009
    no audio no matter what i try on modle str-v444es
Thanks so much for your response to my problem. Last night for some unknown reason I couldn't get into the manual for my devise. This morning I got into it and found the other Volume control and discovered it had somehow gotten to 20% instead of 90-100%! I fixed that and am now set to go again! My "Car Butler" is talking to me loud and clear. Thanks again.
Lady Lou
Posted on Feb 16, 2008
Amplifier powers up. low humming, and music is barely heard at full volume.
The main amplifer ICs have taken a dump. Time to go shopping!
Nov 15, 2011 | Audio Players & Recorders
What is dynamike gain cotrol on a cobra cb radio
Dynamike Gain Control varies the microphone sensitivity. When set fully clockwise, it is very sensitive - and will be able to "hear" background noises easily. This position also can cause your voice to be distorted or garbled when approaching maximum under the right conditions as well as causing "bleed over" to adjacent channels. When set to minimum, you will need to speak clearly and directly into the microphone to be heard. Most people find a setting somewhere in the middle works best.
You should adjust the level to suit those that are listening to you by asking them if it sounds OK. This prevents them from having to turn their volume down whenever you speak. In a "one-to-one" conversation it is not as noticeable. The trouble comes when 3 or more are conversing. The third person's audio may be low or normal - and the listeners set their radio's volume so that they can hear that person easily. Then you transmit with booming mic audio and everyone scrambles to turn down the volume to save their ears / speakers. This can be very frustrating for the others having to constantly adjust the radio volume whenever you speak.
I hope this helps and good luck. Please rate my reply - thanks.
May 18, 2011 | Cobra GPS
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Which input do i plug my lead into high or low
High for most things, especially connections from other powered audio equipment. Low for things like phono cartridges, connecting directly to an electric guitar and most microphones.
Generally, you won't try anything by trying the high first. If you do that and can only hear the device very faintly with the volume turned to medium, then try the low.
Jun 20, 2009 | Audio Players & Recorders
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Apr 19, 2009 | Samsung HT-X50 System
SOLID AUDIO F-45 4CH 900W ONE OF THE FRONT CHANNELS ...
HI DUDE TRY TO CONNECT ONLY 2 PC OF UR 6x9 AT FRONT CHANNEL TRY IT OUT COZ IT MAYBE THE DONT HAVE MUCH POWER TO HIT VOLUME OR ELSE TAKE OUT UR SUB CONNECT TO FRONT CHANNEL OR CHECK UR SUB VOLUME .,...
Apr 01, 2009 | Solid Audio Formula Series F45 4-Channel...
I lost Audio output Device No audio output when using turntable. Can hear sound with headphone, can hear sound when hooked directly to speaker. Can not get sound out of audio output. Plugged RCA cables...
turntable needs high sensitivity preamp. the output level is so low that it has to be amplified more. usual inputs of turntable are phono input. needs a high sensitive input to handle.hope this help.
Aug 08, 2008 | Kenwood KR-V7080 Receiver
61 people viewed this question
 Grubhead
Grubhead
