Question about Kenmore Elite HE4 Electric Dryer
SOMETHING stuck inside the dryer body - something like a coin... let me knwo
The dryer has something stuck in it. It may be a coin. Its behind the drum. Can I open it myself to see what's inside? Let me know. Thanks.
  • 6 more comments
  • Elevate Feb 16, 2008
    Is it easy to open the baffles ?
    Can I do it myself?
    should I have a professional do it?
    Let me know.
    Thanks
    Hello
    Thank you so much for the help.
    My email is elevatemarketing@aol.com
    The dryer info is as follows:
    Kenmore Elite Front Loader
    Quietpak9 - HE4
    MOD: 110.85088400
    SER: MS 0804005
    TYPE: DADT - ELE - 2406028 - EL 54
    Thats the info on the serial label on the inside of the door panel.
    Please let me know. Thanks so much. I truly appreciate your efforts.
    Regards
    Dana
    Hi Master-Tech,
    I am basic in my mechanical ability.
    If its a matter of removing the screws in the back and finding the penny, it should not be an issue. If it requires adjusting belts and electronics and all, it will be more difficult.
    Let me know.
    Thanks.
    Dana
  • Anonymous Mar 17, 2008
    The coins are behind the baffels. just lossen the screws on back of the drum and they will fall out
  • T Gindles Mar 19, 2008
    Hi, I have a Kenmore Elite electric dryer model# 11061082000 and there is a noise like a coin stuck in the one baffle. I need to know how to open the dryer correctly to loosen the baffle to remore this object from the outside of the drum. Please tell me how to open dryer cabinet from the top of the machine or bottom. Please help this is loud and it's driving me crazy. If you have any other knowledge of something making a noise like this that would help too. Thanks, TG
  • Gary Davd
    Gary Davd May 11, 2010
    From What I see here you cant just take them out the drum will have to be removed.. how mech inclined are you??
  • Gary Davd
    you can do it post your model number here and i will get you a pic and instructions on how to do it if you want you can post your email as well
  • Gary Davd
    more that likely it is (the coin) in the Baffles you can open those from the inside of the drum
  • 770 Answers
Ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ...ie ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Posted on Feb 16, 2008
Cl300 dryer has stopped going around and is making a deeeeeeeer sound , any ideas
Could something stuck between the drum and the wall inside. turn it by hand and see if it moves. IF it does then there is a belt that wraps all the way around the drum and it might be loose or off track. IF it does not turn then look for coins etc that are stuck.
Oct 24, 2017 | Dryers
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
SOUNDS LIKE UN HAVE SOME ITEM OR COIN ETC STUCK BETWEEN THE TUB AND WALL. YOU HAVE TO REMOVE THE TOP PANELS THEN REMOVE RETAINER CLIPS AND REMOVE THE BODY TO ACCESS INSIDE DRUM
Dec 12, 2016 | Kenmore Washing Machines
My Kenmore Steam dryer 796.8044 model drum won't turn
There are some things that you need to check. First see if you can turn it with your hand and note if it is easier or harder. Then you have an idea if it is something stuck or something failed. To see if it is the belt, you need to pull the top of the machine off and then you can see the outside of the drum. The belt may be off the motor, the tensioner or it may be broken. If the symptoms suggest it is something stuck, a coin or something hard like that is between the wall and the drum. IT could also be a bearing. MAKE SURE YOU UNPLUG IT IF YOU TAKE THE TOP OFF. Here are all the diagrams: http://www.searspartsdirect.com/kenmore-dryer-parts/model-79680448900/0582/0151200.html
Jul 24, 2015 | Kenmore Dryers
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Zanussi jetstream 1250 coin between inner & outer drum
not that easy.
remove top. remove water hoses.remove rear half of cabinet. to do this, undo securing screws along top flange, remove two screws at bottom sides hidden behind plastic plugs and two screws at bottom back. rear half of cabinet will then pull off.
remove heater - this is held with a 10mm nut in the centre which loosen and prise heater out.
you canb then see into the gap between tub and drum ane remove coin or whatever
Nov 05, 2008 | Dryers
Is there a schematic for the Kenmore Elite Oasis gas dryer model no. 110.7703*, 7704*? I think a coin or something got inside and it now makes a noise when in use. I cannot for the life of me figure out...
you can remove the lower acees panel ( 3 1/4 screws across the very bottom of unit, this will give you acess, to the insideto better pinpoint where noise is coming from, also across the top of the back of the unit is 3 screws holding down the top assy, by removing this youll be able to access the screws hodling on the inner drum paddles( incase the coin(s)), has gotten between there
Apr 24, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
2,807 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
