Question about Proview PL713S 17" Flat Panel LCD Monitor
BenQ FP51g LCD monitor
Display comes on for 5-10 seconds and then black.Power led is on all the time.Switch off monitor and switch it on Display again comes on for 5-10 seconds.Semiconductors on Inverter board are ok checked by replacement.Problem is on the power/inverter board panel is tested known ok.
Any help appreciated.
  • 1 more comment
  • Samir  Shah
    Samir Shah Feb 23, 2008
    I am a techie myself and this is specific problem of the inverter board.The pc interface board etc are all known tested ok.Definitely not driver or refresh rate issue.
  • bearsam May 30, 2008
    the monitor green diodes lights up then goes to orange before the screen has a chance to display anything..the pc is still running can you help me..cliff
  • AADD Dec 23, 2008
    I have the same exact problem...started yesterday and is driving me crazy. Should i just go get a new monitor???
    A
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Posted on Oct 25, 2008
Yes, yes, same problem here too. Here is how I solve it:
BenQ FP51G uses a dual voltage supply. One is at 3.3V to supply the logic board (we call this output A from the power supply). The other one is to supply the CCFL backlit inverter (we call this output B from the power supply). It seems that the CCFL backlit turns on when output B reaches 25V and then turns off when the voltage drops down to 20V or 13V. I don't know what is the spec for this B supply (possibly 15V since FP51G's sister, FP71 uses 15V). I know that B supply is supplying approx 100mA into the inverter circuit, so there is not short-circuit here or a transistor blowing up somewhere.
My temporary solution is to disconnect the B output (there is a jumper with a ferrite bead on it), and replace it with an external 24V supply. Voila, the monitor is now on a new lease of life.
I don't know what is the root cause of this problem though. Possibly the CCFL is getting old? Not sure. Everthing else, including the so called capacitor leaks/bulges is just not here. I replaced the B supply capacitors and still have the problem. Therefore my last resort solution of an external supply.
Someone mentioned to short a transistor from the B output to the inverter circuit. Yes, maybe that too is possible. However, that transistor is not just a BJT, but a MOSFET, and I believe its function is to adjust the input voltage into the inverter circuit (that MOSFET is a buck converter with a TL1451 driving it). Maybe it has something to do with brightness control.
Good luck and have fun with it.
- Kortsleting
Posted on Aug 05, 2009
I have
Posted on Jun 26, 2008
  • 33 Answers
Try loading windows in safe mode to see if it works.
Posted on Feb 18, 2008
  • Ed Paparo Jul 28, 2009
    If you didn't fix it yet, definitely look at the capacitors on the boards. I just fixed a monitor with the same problem by replacing bulged, leaking capacitors.
    Brigadier General:
  • 6,966 Answers
If there is constant and regular main B+ supply powering the inverter and the other circuits, then possibly the PSU (not as posted "Problem is on the power") should check out OK. And as you posted/described, "Semiconductors on Inverter board are ok...inverter board panel is tested known ok"
Might it be that there is nothing wrong with the monitor?
Perhaps what might be causing the display to be gone in 5-10 seconds is that the video signal it is receiving is beyond its capability and therefore having a hard time to compensate and eventually switches off.
Just to verify that it is not an internal fault within the monitor but probably the PC;'s setting that is the root of the problem, pls as a test run your PC + monitor with:
1. lower screen resolution of your desktop's properties.
2. it may also be of help if you likewise lower the screen refresh rate.
Both of the above may be adjusted through the appropriate settings in your Display Properties.
If your concern has not been corrected after completion of the above procedures, pls post back details of your video card (brand/model), display properties settings: a) screen resolution, color quality and Advanced/Monitor screen refresh rate.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 16, 2008
  • Louie  Role
    Louie Role Feb 23, 2008
    Hi again,
    Thanks for the update.
    Could you pls check if you are you getting constant high freq/high voltage from the inverter or does it goes on & off too? Another to check is if the B+ supply to the inverter board is constant?
    Would appreciate if you can update results of checks.
    Cheers.
Black monitor screen fp51g q5t4
> Check Windows proper running or not.
> Have a HDD problem, so check it.
> Check keyboard num Lock coming light or not. If not coming light then RAM problem.
> If all thing is ok then change monitor scree.
Thanks..
Sep 05, 2013 | BenQ FP531 15" LCD Monitor
Display problam
On the monitor power board you find an IC called push pull transistors,it is usually paired get to read this IC with your miter a pair of this IC must have gone bad.If dictected replace it, then power the power board and it will display normal.Thank you Jesus.
Apr 21, 2011 | BenQ FP51G 15" LCD Monitor
The model of the BENQ Lcd Monitor is FP783 When I open the Monitor it is working around half an hour later on the screen become black but the the led is remain on. If you wait the screen never come back...
There are two boards that I would be checking, the power supply often has bulging capacitors that need to be replaced, the second concern is the inverter board has usually two three that need to be addressed, 'very common problems" the inverter energizes the back lights.
Jan 31, 2011 | BenQ FP783 17 IN LCD WEBCAM/SPK Monitor
Benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Dec 17, 2010 | BenQ FP51G 15" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Benq monitor fp51g
What's the owner's manual say that means?
Jan 13, 2007 | BenQ FP51G 15" LCD Monitor
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
871 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
