Question about Philips 42PFL7432D 42 in. LCD Television
Sound Problems with Model #42PFL7432D
I have a Philips Ambilight 2 42" Flat Panel LCD Model # 42PFL7432D.
Sometimes the sound goes out completely when I turn it on or when switching from DVD back to Cable.
If it goes out, I can usually fix it, by switching back to DVD or GAME and starting a DVD or Game to get the sound going.
Then I switch back to Cable and the sound is usually back on.
But, it is very frustrating to keep having to do that when the sound goes out.
Any ideas on what the problem might be?
Thank you,
Stephanie
  • missphnx Feb 26, 2008
    The upgrade did not fix this particular problem.
    I call Philips support and after thorough trouble shooting, it was determined that the problem is with the HDMI compatibility on the DirectTV box.
    So, it isn't a problem with the TV at all.
    The problem can be fixed by hooking up the DirectTV box with component cable and not HDMI.
    Thank you anyway
    Sergeant:
  • 395 Answers
You will need to upgrade the software. go to the philips web sight and download the upgrade from the support tab. read the instructions first. you will need a USB flash storage to down load it to
Posted on Feb 25, 2008
Philip 42pfl7432d/37 has sound, but no picture, what is wrong?
Tv turn on now,pictures only flashes few sec. than dies have audio left only?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
May 11, 2011 | Philips 42PFL7432D 42 in. LCD Television
My philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
May 18, 2010 | Philips 42PFL7432D 42 in. LCD Television
Tv worked last night. This morning, no picture, no sound but ambilight works as normal...any clue??
this could be caused by vented capacitors in power supply..........look for domed tops on the electrolytics(small can shaped devices)on power supply board. These are bad and need replacing. 1000uf 10v.
Replace with high-temp(105 degrees C) electrolytic cap.
I use 25v or greater. Good success........meder'sTV
Apr 01, 2010 | Philips 42PFL7432D 42 in. LCD Television
I have no image, or if i look very closely, there is a very faint image. sounds/remote/ambilight work fine. tech came and determine the inverters needed to be replaced. I ordered them, and installed them....
Only one board left,replace the Main Tuner signal board.After that same problems.Than ur LCD screen is dead.This problems only can cause by two,boards.You already try one.
Mar 15, 2010 | Philips 42PFL7432D 42 in. LCD Television
I have a philips 42pfl7432d lcd tv, where the sound works, but the picture does not come on. Ambilight works with the remote
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur pictuure back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlighht board for the replacement.It a long board in shape.
Mar 09, 2010 | Philips 42PFL7432D 42 in. LCD Television
I need a replacement LCD panel for my Philips TV. the model number is: 42PFL7432D/37 where can i buy it?
unless it's under extended or manufacturer warranty...not cost effective to replace. You can get it at partstore or shopjimmy.com if this is the case. Good success.....Meder's TV
Feb 01, 2010 | Philips 42PFL7432D 42 in. LCD Television
Philips Ambilight
most likely its the audio amplifier board where your having the problems
Jun 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PFL7432D 42 in. LCD Television Logo
151 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
