How to reboot cpmuter
How to reboot computer
  • Anonymous Apr 06, 2009
    how do i take my computer back to factory settings
  • 407 Answers
If you want to install your OS you setup your pc properly.
Posted on Feb 16, 2008
Software download
buy another ....this cannot be fixed
Feb 01, 2014 | Samsung YP-U5 MP3 Player
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a problem with my monitor it a mag 18" LT865b the power light comes on but nothing shows up on the screen i have tried many different things such as different power cords even when not pluged...
Most likely, one of two things are the problem. Assuming that your computer is actually starting up and it passes the POST (you'll get a single beep if you have a system speaker), then the monitor is likely bad. Check it by attaching another monitor to the computer to see if a signal is being put out by the computer. If you get a picture, you have definitely have a bad monitor. If there is no picture on the test monitor, then your video card may be bad.
If the computer is not starting correctly, I'd recommend disconnecting everything but the CPU and memory and possibly the keyboard and trying to boot it. If it's one of the peripherals like the CD/DVD that is bad, then you should get something on the screen (I have had this happen).
Oct 30, 2010 | Mag Innovision Computers & Internet
Dear Sir, I have Nokia N95 8gb. I need put passwoord with internal memory card or any folder for saftey. How can i do it?
u can enter a password to your memory card by going to menu>gallery>memory card>options>enter password. bt it wnt get locked in cell phone. if u connect it to external cpmuter then only it will work.
Oct 29, 2009 | Nokia N95 Cellular Phone
Why wont my cpmuter show my webcam?
try control panel and camera scanners etc then open, maybe this may work
Mar 10, 2009 | Logitech QuickCam Express Web Camera
LAPTOP 1502 DVD
right clik on my computer go to properties then hardware then device manager then find dvd rom drives then uninstall it .after uninstall it right clik any icon there then clik on scan for hardware changes.then it search if found any device simply clik next ..if not found turn off sytem .then check your cpu that dvd is connceted proter to mother bord.check data cable and power cable of dvd reconnect it.
then restart the cpmuter yout probelm is most of solved.
Oct 05, 2008 | Everex StepNote NC1500 Notebook
Trying to install on my computer.
Which kind of computer!!!!
Download the appropriate driver for your DVD player . for to be very sure about what you are doing, right clic at my cpmuter , manage, then clic at device manager . When the list will display, check where you will see the question marks.That hardware will not be installed properly . In that way you will be asked to resinstall again that component.
but all this will depend of your software, windows95 2000,.
if you are not try to provide more information about brand, model of your computer the operating system you use , brand and model of your DVD player. and also what you want really do.
Sep 24, 2008 | Televison & Video
Hp Photosmart c3180 Recovery Plug-in missing on vista
Hi I had the same problem for a week as I had rebooted my computer - I had been conversing with HP support for a week and still could not get it to work. Yesterday I got advice that worked....if you installed internet explorer 8 on your laptop uninstall it in add/remove programs (control panel) then make sure you have all open windows close and go to "start" > "run" and type %temp% press "ctrl" + "a" and delete all temp files. Then restart cpmuter and try installing the hp software again. Any problems let me know.
Sep 10, 2008 | HP Photosmart C3180 All-In-One InkJet...
Will connect to more than one cpmuter but no internet options
It would seem that you posted twice....
My response to your other post:
On your post "WILL CONNECT TO WIRELESS BUT NO INTERNET OPTIONS" this would be a configuration/settings issue more to do with TCP/IP. Pls post back what modem and your ISP (provider).
On "ONLY ON LAPTOP WILL WORK AT A TIME", do you mean you would want to use the Internet on more than one computer? If yes, then you would need a router to share the internet connection.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Computers & Internet
SanDisk Cruzer Titanium 2.0 GB USB Flash Drive
It sounds like it is trying to use the E: drive and it is already in use? If so while you have the flash drive installed right click on my computer /click on manage / on the left side click on disk management / on the right side you should see the C: drive with other if you see the flash drive in this list with no drive letter right click on it / click on chang drive letter and give it a G: or other letter not in use. you will get a warning click ok and exit out your drive should appear. (note this is for windows xp)
Oct 13, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Computers & Internet Logo
740 people viewed this question
David Payne
David Payne
