Question about Proscan 32LA30Q Television
Connecting my home theather system to my ps32la30q television set!!1
I went out an purschased cables for my television with the gree, blue, and red connections but the cables are still not working. I don't know if I'm placing the proper cables into the proper slots. Please help me with this problem...
  • big al watts Feb 16, 2008
    The model on my television could either be the Pro scan 26la30q or 32la30q does the 26 and 32 represent the size of your television set or what??? I not that good when it comes to electronics...
  • jeannebridea Jan 18, 2009
    I have a wireless home theater system and only the plug speakers plays
    Sergeant:
  • 280 Answers
Make sure you have connected your cable to audio lines out not any of the line in's on the tv then check to be sure you are connected to the line in on the home theater amp
Posted on Mar 07, 2008
Manual for rca home theather rtd 3136
How old is your TV? The red, yellow, white cables will go on the back of the TV.
Mar 16, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
How to hock up surround sound to tv
I'm sorry that the solution has to be so general, but there are not sufficient details in the problem to give the exact answer :(
If the television has an audio output, which would have a red and white hole and say out(put), you would connect the red and white audio cables to the home theater in the corresponding red and white input a/v holes
If you are connecting all of your devices to the home theater for picture and audio, you are connecting from the outputs of all of your devices into the corresponding inputs of your home theater, and then connecting one hdmi cable from the output of your home theater into one of the hdmi inputs of your television.
You can also choose to connect your devices to your television just for video (so hdmi cable or yellow cable or red, green, blue cable to the television's inputs) and to the home theater for sound (another hdmi cable from your device to your home theater or white and red audio a/v cables from your devices to your home theater).
Dec 01, 2012 | Audio Players & Recorders
Color bleeds
test first a) Video detector, then 2) AGC, adjust control, circuit 3) color Sync 4) color occ 5) color killer 6) color i-f 7)DEM red-gree-blue+videoamp red-gree-blue finally YOKE.see the b.diagram attached.
God bless you
Oct 17, 2012 | Televison & Video
Cameras seem to be out of adjustment .getting gree,blue,and red images.not lined up how do i adjust?
There will either be a button on the TV for convergence or you may need to use the TV remote to go into the menu under settings or advanced set up to find the convergence adjustments, they should allow you to move red and blue to try to align to green. If one of the colors won't move it's time for repair.
Feb 28, 2011 | RCA P52945 52" Rear Projection Television
How do i connect it to my tv so i can have surrounf sound when watching tv
if you look at the instruction manuakl that came with the theater system:
http://www.retrevo.com/support/RCA-RTD3133-Home-Theater-Systems-manual/id/23608dj495/t/2/
under connections and set up there are two ways of connecting up a tv
hopefully your tv has a audio out phono jack
using phono jacks connect the audio out from the tv to the AUX in the theather system
then select AUX in the theater system and then press the surround button to select sound modes
if your tv does not have a audio out jack look for a optical digital out socket in the tv and then use that to connect to a optical digital in in the theather system
May 11, 2010 | RCA RTD3133 Theater System
The blue cross will not move left for the convergence. Used a universal remote to link up to the menu. In the TV menu can move from red to blue and red will move. Blue will move up and down but not left....
1.) If the blue will not move left and right you have a convergence circuit problem.
2.) Most of these sets use 2 STK-392-110 CONVERGENCE output IC chips--they along with any bad resistors around them need to be found and replaced.
3.) You can buy the chips for less than 14 dollars on Ebay plus shipping--if you are able to do this repair yourself you can save a lot of money as most TV repair shops charge 300-400 for this kind of repair.
4.) If you cannot do the repair shop around in your area and if they say it "has to go to the shop" keep looking as any good tech can do this repair in your home in about 1 hour.
5.) If you have any questions or need more information reply to this posting here and I will assist you.
REGARDS, SD TECH
Sep 23, 2009 | Toshiba TheaterWide 46HM84 46" Rear...
How do I hook up my home theather system using my HD DVR cable box ?
There should be, on the back of your cable box, the A/V hookups. Look for the area in the cluster that says Audio Out. It is all color- coded, so should be pretty explanitory after that.
Jan 20, 2009 | Televison & Video
Rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Jan 03, 2009 | RCA L37WD12 37 in. LCD HDTV
Connecting a Protron PLTV 3250 to a home theater system
Standard RCA cables are fine to connect both units. If home theater and tv has Component Video (Green-Red-Blue) connections, you can get better video result.
Sep 11, 2008 | Protron PLTV-32 Television
Color on the screen
Try moving the speakers away from set.
May 11, 2008 | Orion1934 19" TV
Proscan 32LA30Q Television Logo
67 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
