Question about Panasonic DMR-ES46VS DVD Recorder/VCR
Audio noise on some, but not all VHS tapes
I just purchased a refurbished DVD/VHS combo player. It plays most VHS tapes fine, but I have a tape by Famous Cycling Videos: Tete en Course, that has a low pitched rumble like static that accompanies the sound track. On my older Mitsubishi deck it plays fine. My refurbished machine has a 90 day warranty. I could send it back, but since it plays other tapes correctly, I'm not certain the problem is the machine. Do you have any idea what the problem is, and how I could solve it?
  • kayakfit Feb 19, 2008
    I'd like to thank coolguy008 for his comment regarding the tracking adjustment. It worked perfectly. Its funny, if I had been clever enough to read the troubleshooting section of the owner's manual I would have seen the same suggestion. Ironically, when I put the problem to Panasonic they never suggested it, nor did the Fixya staff writer. Good job coolguy008!
    thanks, Ken
    Brigadier General:
  • 6,966 Answers
Most VHS tapes can be recorded on different speeds which are commonly called: SP, LP and EP/SLP. For the same given tape, the amount of recording time can be extended if the LP or the EP/SLP recording speed are selected. Most quality standard recording is done using SP, however, some videos that require more viewing time tries to squeeze in all the contents in a single tape and the only way to do this was to run the tape slower than standard thereby more video can be recorded. It is some form of compression.
Often this difference in the recording speed becomes apparent when played back in different units which manifest itself as rumble like sound in the background. It is also possible that the tape has been slightly stretched making the slow speed recording/playback not 100% compatible with different machines.
One way to verify whether the Tete en Course is using LP or EP/SLP and not SP is to compare the how fast the tape counter counts. Run a known standard good quality VHS tape and note how the counter reacts. Play the Tete en Course tape and determine if there is a difference.
Should you be adventurous, you can open the top cover of the unit to view the spool window and compare winding speed at standard play and the VHS tape in question.
There is no standard corrective procedure since trying to make the rumble disappear might shift the problem to standard speed playback of regular tapes which would affect audio quality of the rest/most of your tapes.
Of course there is no stopping you from requesting for a replacement unit just to play it safe.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 16, 2008
  • Louie  Role
    Louie Role Feb 19, 2008
    Hi kayakfit ,
    As it was the manual tracking that solved your problem, perhaps it would be more appropriate to rate coolguy008's as Fixya rather than mine.
    And pls I am not a Fixya Staff writer, just one of many members of the Fixya Community. Nonetheless, am still glad that your tape can now be played correctly.
    Cheers.
    Genius:
  • 3,422 Answers
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
  • Priya darshan Feb 19, 2008
    Hi again Kayakfit good to hear that your problem is solved..
    And thanx for using fixya..
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
Clicking sounds when playing VHS tapes
On one hand I would say not to be concerned about the clicking since nothing seems to be affected. However, if the noise is loud enough to be a bother, or for your own peace of mind, consider returning it to the retailer for exchange if you still have that option. I've heard clicking sounds from other VCRs because of some of the moving parts and it's been nothing to worry about. But I'm not familiar with the guts of your model, so I can't say it's not a sign of some problem that might get worse over time. It's your call. Not really a "solution" I know, but without opening it up for myself and looking for the source of the noise it's the best I can offer.
Apr 25, 2009 | LG RC897T DVD Recorder/VCR Combo
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
VCR
Hi dennis176,
Unfortunately, I am not aware of this kind of setup. This kind of solution would not be very efficient. For this to work there would need to be an insert to the VCR (similar to that which is used in a cassette player to convert CD audio) attached to a DVD player. Because you would require a device to play the DVD and send the video/audio to the insert (if it existed) it would actually be more efficient to simply connect the DVD player to the television. The reason inserts exist for cassette players is primarily that it prevents replacement of an entire car stereo system. This is not the case with a VCR. You may consider purchasing a DVD/VCR combo if you wish to maintain the ability to play VHS tapes. If you own a TV/VCR combo, your least expensive option would likely be to purchase a separate DVD player.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Emerson EWV603 VHS VCR
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
Panasonic DMR-ES46VS DVD Recorder/VCR Logo
128 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
