I had added music before no biggy to it when I try to add anything no matter where I get it from it says basicaly to bad for me . I thought maybe I had to delete some but I am no where near the 42 hours of music of 650 songs it says I can have.
Now I am frustraed opeining it up in I drive does nothing but show me what son but I can't change anything HELPpppppppppppppppppppppppppppppppppp Please
In Windows Explorer, right-click on your drive I: and select "Properties". In the displayed window will be two numbers, "used space" and "free space" ... make sure you have enough free space to hold the music you're trying to copy to it. If you think you have enough free space, post back with the numbers, and we'll go from there.
Should not hurt anything,means the air injection system isn't working. emission code,a pump adds air to the exhaust on cold start,no biggie Most likely a vacuum hose ,check by the brake booster,listen for a hissing sound.May have to pull the plastic engine cover to aid your hunt for a broken hose. ,,
In order to add music to your mobile you have to do it through your mobile itself. You can copy any number of songs to your memory card according to the memory available. Then start your media player in your phone go to options and select update media library. Your media library will automatically search for music media and add it to your playlist.
Select "Plugins which are used by the Internet Explorer" from the drop-down menu. Then disable. Change the home page using internet options. Clear all your temp files and cookies. IF anything does not work, then go to add/remove programs_>add/remove windows components and remove the IE and re-install using the same place after rebooting.
Click on the following link to create & transfer music to your mp3 player. I assume that you have the tracks in your PC hard drive (My Music folder). If not if you have them in a CD, go ahed and insert it on to the PC and then Rip the music using Windows Media Player.
Sansa e200 - creating & transferring playlists
Let me know if you need further assistance!
make sure that all of your id3 tags are correct and filled in for each music file before dragging and dropping. initially when i added files to my vtouch, the player recognized them automatically and added them to the standard playlists. every time i add files now, i have to manually add each one to the playlists by touching MUSIC > ADD TO AUDIOLIST > ADD TO AUDIOLIST. Then you should be in the AUDIO folder. Double touch AUDIO to view it's contents (which should now be your 'artist' folders, if you organized it that way). Go into an artist folder and double touch each track to add it to the playlists. You should see a "wait..." message and then "success" for each track you add. BUT they are not added yet, my friend. I KNOW! WHAT A PAIN!!! So when you are done adding tracks, you need to touch the back arrow to get back to the MUSIC menu. Then touch UPDATE AUDIO LIB. This may take a few minutes depending on how many tracks you added. When it's done, you should have all the tracks you added in all of the playlists.
It says no files cause you put the wrong music on the unit anything that isnt .mp3 or .wma WILL NOT WORK! you will just get a message that says no files!
