Question about Electronics - Others
Memmorycard my memory card became write protected can you plz help me to remove the write protection
  • 3 more comments
  • Anonymous Sep 15, 2008
    I have the same problem, how can I remove the write protected?
  • ravi_1pr Jan 11, 2009
    4 gb MICRO SDHC came wite protected dunnnow how to remove it the swith on the adapter doesnt work ?
  • lubber_Jess_ Mar 21, 2009
    sony memory stick pro duo 2 gb has write protection cant get it off and ther is no switch
  • srikks Mar 21, 2009
    It is write protected. Can anyone tell me how to remove it?
  • Anonymous Apr 10, 2009
    how can remove write protection by micro sd memory card
    Novelist:
  • 104 Answers
First of all what type of memory card are you talking about? SD for example has a little plastic piece that moved to one side blocks the card from writing and to the other side allows writing data on it... but i dont know what type you have... would you tell me to help better?
Posted on Mar 18, 2008
  • 49 Answers
Open regedit and go to :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
find the value WriteProtect and double click to edit it's data and set it to 0. __________________
Posted on Dec 16, 2008
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
I forget my phn code of n72. And i want to format my phone. My memory card is courapted now what i should do. I forget my memory card pasword plz help me.
HI, U CAN UNLOCK YOUR PHONE. FOLLOW THE INSTRUCTIONS-----1) DON'T TURN OFF THE PHONE 2)REMOVE MEMMORYCARD FROM LOCKED PHONE AND PUT IN AN MEMMORY CARD READER. CREATE DIRECTORY E:\SYSTEM\RECOGS AND COPY THC-NOKIA-UNLOCK.MDL INTO THIS DIRECTLY...... ORYLY 3)REMOVE MEMMORYCARD AND PLASED IT INTO LOCKED PHONE...THE THC-NOKIA-UNLOCK-PROGRAM WILL START AFTER 120 SECONDS 4)REMOVE BATTERY AND MEMMORY CARD .PUT BATTERY BACK AND RESTART ...THE PHONE LOCK IS RESET TO 12345.TO FORMAT YOUR PHONE USE THE CODE *#7370#.MEMMORY CARD CAN BE FORMATTED BYU SING THE CODE *#7780#..THANKS
Nov 18, 2010 | Nokia N72 Cellular Phone
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
How do i clear 'write protection' from a removable Flash drive?
rt click the removal drive ..properties...uncheck read only.....click on the tab security...add everyone ...give full control ...apply ..ok ...it should work now..
Mar 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protection from my pen drive
Dear,
Just do one thing
Copy the data of Pen drive to PC and format the drive. Now paste the data back to the pen drive.
It may work fine onward.
Please try it.
Regards,
Rakesh Kumar
Apr 07, 2009 | Kingston 4GB Secure Digital High Capacity...
Write protected
you didnt stop the device before removing it.
now it is stuck in read only mode.
try replacing it if it is still inside warranty.
and be more careful next time
Jan 22, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory card write protected
As you are looking at the top of your SD card (the side with the name on it) on the left edge of the card, there is a tiny tab (usually gray), slide the tab up to unlock the SD card. Sandisk brands say the work lock on them, lexars do not. hope this helps. Steve
Dec 19, 2008 | Cameras
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
How to remove write protected memory card pls help me
Jun 13, 2008 | Nokia 6680 Cellular Phone
Electronics - Others Logo
697 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
