Question about Olympus FE-180 Digital Camera
I need help
when i turn my camra on
it says card errow
Turn power off
Format
Ive clicked Power off a million times
along with format YES & NO !
When i click format then yes
it says
[xD]
then like a [!]
CARD ERROR !
i neeed help
emma_dogsrox@hotmail
please send me the answer to that.
thanks !
    Scholar:
  • 154 Answers
I think you must have a xd card with an error , go back with the card and the camera to where you bought it because it must be a xd card error
Posted on Apr 19, 2008
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
How do I format the sd card in the DMC_ZS7
Welcome to FixYa.
To format the SD card, select [Format] from the [Setup] menu
To bring up the Menu option, press the Menu/Set button. Then select [Setup] and then select [FORMAT]. Then choose Yes to format the card.
Please note:
This requires a sufficiently charged battery, or an AC adaptor (optional) and DC coupler (optional). When
formatting the built-in memory, remove the cards.
(Only inserted card will be formatted if present; built-in memory will be formatted if no card is inserted.)
• Always format cards with this camera.
• All picture data including protected pictures will be deleted.
• Do not turn off power or perform other operations during formatting.
Thanks for using FixYa.
Feb 11, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
I have HP Photosmart R827 with the same problem. when I was uploading stuff onto my memory card I might have hotlinked and when I disconnected it said "Card Unreadable" and told me to format. i...
memory cards can become damaged. this can be from removing it at the wrong time or a file become corrupted, it can wipe the format off the card. and will need reformatting. dont do this on the camera as it can put the wrong format on the card. doe this on a pc, it will probably say when you instal the sd that it needs formatting. click yes, a box will appear and have it all set out for you but don't click format yet, in the box where it says restore device defaults click this. and then press to format. this will put it as the best for any device its being used for. if you had anything on the sd card before it will not be there before or after the format. hope this helps.
Jul 01, 2017 | HP Photosmart R827 Digital Camera
Camera say i need to format it because of a card error
First, get a card reader and download your pics to a computer. Then, format the card in the camera.
Jan 29, 2010 | Samsung L200 Digital Camera
My sansa clip is frozen how do i reset
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using media player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu, Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
My Mp3 player is frozen on a file it says it's chargeing when its not
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa m250 MP3 Player
My Blackberry Curve 8330 won't format a media car
From the Home screen of the BlackBerry smartphone, click Options > Media Card or Options > Advanced Options > Media Card.
Display the menu and click Format Card.
  • some times Format Card option does not appear on the menu, skip the step and perform the procedure that follows.
  • A warning message will appear asking if you are certain you would like to format the card. Click Yes to continue.
    If the Format Card option does not appear on the menu, complete the following steps:
  • On the Media Card screen, set the Mass Storage Mode Support field to Off.
  • Display the menu and click Save. The Media Card screen closes automatically.
  • Click Media Card to reopen the Media Card screen.
    To format the media card, display the menu and click Format Card.
Nov 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Card errow can i format the card or buy a new one
Be careful!
• This operation will destroy all data in the card. If you have already used the card, be sure that you are not about to destroy important image data.
• Some cards come equipped with special built-in functions. Formatting such cards may in some cases cause them to loose their functionality. Before formatting a specialty card, please read the documentation included with the card.
• You cannot format a card that is protected by a write-protect seal.You must remove the seal before formatting. Please discard used seals; write-protect seals should not be reused.
Go to Menu and select the trashcan. Select the symbol that looks like a hammer. Select Yes or No.
CAUTION
• You cannot cancel formatting once the camera has begun executing the format. After selecting YES and pressing the OK button, you must allow formatting to proceed.
• Do not open the card compartment cover, remove the batteries, or disconnect the AC adapter while formatting is in progress (while the lamp is blinking), as doing so may damage the card.
May 09, 2009 | Olympus Camedia C-211 Zoom Digital Camera
W850i memory stick
hi there,
            I dropped my sony in water once and the screen stopped working completely , I had to replace the lcd screen myself in the phone, (which isnt that difficult with a sony ericsson , it damaged the lcd screen but not the rest of the mobile...so this sounds like your software has been corrupted or the memory slot contacts have developed a fault from the damp
        Try the master reset function (remember this erases any security pin numbers you might have put into the mobile) and see if the problem persists.If your brave enough ? like me ! you could strip the phone down and blow it dry with a hairdryer (set on low temperature), look for gunk on the memory card contacts and clean these off with computer solvent cleaner and a cotton bud.Then update the firmware and the software from sony ericsson's website.But I have a feeling , that the water got inside and this has coated one or more of the contacts for the memory card with the same thing , that you get inside a kettle,literally scale has formed on one of memory card contacts.
Aug 31, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Olympus FE-180 Digital Camera Logo
82 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
