Question about Sony Xplod XM-1652Z Car Audio Amplifier
Amp protection I hooked my two 12' 800W kicker's to the amp...got all the wires connected and everything...it even started working for about 1 min. and then all of a sudden the protection light kicked on and the amp kicked off...when i turn on my CD player and the song is about to pushin bass the amp goes off...also only 1 of my subs is now coming on, when it does come on for that short period of time
  • Anonymous Jun 08, 2008
    i have a explode amp and am not shure what the (rem) hooks up tomy amp is about 4 years old and is 500 watt
If the speakers are dual coil and you have 2ohm stable you will need a amp that could handle 2ohm stable like a kicker amp.
Posted on Jun 12, 2008
No. i've got the same problem. at first i thought it was because my box was too small, so i built a new one, and the protection still kicks in.
any ideas?
Posted on Mar 12, 2008
  • 631 Answers
Does it go into protect if you disconnect the speaker wires from the speaker terminals of the amp?
Posted on Feb 17, 2008
I have 2 kicker cvr 15 4ohm dvcs and a performance teknique ICBM power 4000 watt 1ohm stable amp when I hook up my speakers 1 ohm it kicks my amp into protect when I wire it at 4 ohms it works fine how do...
Are your subwoofers wired in series or parallel? Check your connections, if everything is ok, the problem is with your amplifier. It might have a blown capacitor inside or its not really a 1ohm stable amplifier. Have it repaired if thats the case.
Apr 11, 2011 | Performance Teknique Car Audio & Video
Can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Jan 19, 2010 | Kicker Solo-Baric S12L5 Car Subwoofer
Speakers cut off when bass goes up
probably the amp going to safe or protect mode judging by the fact that you have 3 subs wired to it i would say it is not 1 ohm stable try disconnecting 1 sub and see if it still happens this will be running a 2 ohm load rather than 1 if it stops happening then you need to figure out a better wiring configuration that will work with your amp.
Jul 03, 2009 | Kicker ZX400.1 Car Audio Amplifier
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
Kicker dx 350 amp
Remove amp from vehicle, connect Directly to Battery, then short REM line to Ground, see if amp comes out of "protect" If it does, you have either a short or a bad connection on your power wires between amp and battery, If testing amp directly to battery and it doesnt come out of protect, it meens you fried the amp and likely your problem is wiring between the amp and the speakers, or even the speakers themselves (shorted) .. If you Drive your speakers hard enough they can overheat and short out after a short blast... anywhere from 10seconds to 45 mins.. depends on many variables.
Jan 25, 2009 | Kicker DX350 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Power Protection Circuit (SORT) Engaged
Umm a ohm meter would help you here. Double check the wires from the sub to the amp...make sure its not shorting out. Try starting the amp without the wires on the terminals...if the protection shows up then there is a short inside the unit and it will need to be replaced/repaired.
Feb 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
131 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
