Question about Toshiba Satellite M30 Notebook
Toshiba Satellite M30 Problem
I am having a serious problem with my laptop. It started awhile ago, when I tried to turn on my laptop and noticed that when I did, it would start to turn on for a split second, but then turn off. Following that, the light that's usually blue when my laptop is plugged in (with the power cord symbol; sorry I can't be more specific) would flash orange eratically.
Usually, if I took out the battery and put it back in, then tried again, it would work. After awhile, it took longer for it to start working (sometimes I'd take out the battery 15 times or something). But normally, it would start working eventually. Additionally, I'm not having any problems with my laptop otherwise (slow running, freezing, shutting down inconsistently, etc.) except that if I put it on standby, sometimes I have the same problem trying to get it back on.
Recently, I noticed that I would put the battery in and, without even pressing the power button, the light would start flashing. If that happens, I can't turn my laptop on at all. If I vary plugging in my laptop and putting in the battery, I can still get my laptop to work (as in, I'm typing on it now), but I'm getting worried that one of these times, I won't be able to turn it on.
If someone could please give me some advice as to what this problem could be, I'd be extremely grateful. I'm going to take it in to a tech place on Monday, but I'd like to have some idea of what's wrong so that I don't have to send my laptop away for three weeks or something. (I'm a student, so being without my laptop is a big problem.)
Sorry for typing so much, but I wanted to give as many details as I could. Thanks a ton. :)
    Genius:
  • 3,422 Answers
Hi Sam,
Most likely you experience a laptop overheating problem and it would be fixed by cleaning the cooling module – the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on. The cooling module helps to keep the CPU cool when the laptop is working. The cooling module includes two parts: the heat sink and the cooling fan. The heat sink is attached to the CPU and helps to conduct the heat from the processor to the radiator. The cooling fan blows on the radiator and helps to disperse the heat produced by the CPU. The laptop will overheat if the heat sink radiator is clogged with lint and dust or if the cooling fan stopped spinning.
If your laptop shuts down after some time without any reason and warning, check if the cooling fan spins. Usually it makes some noise and you can hear it. If the fan works fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air, just blow inside the fan openings on the laptop bottom. If the heatsink is completely clogged, then it is necessary to remove the heatsink for cleaning.
Don't worry just take it to the technician he will solve it out if my solution doesnot work..
Goodluck...
Posted on Feb 16, 2008
    Brigadier General:
  • 3,614 Answers
Power adapters fail because of power spikes. You can do a preliminary test of your system's adapter by plugging it into your notebook and checking to see if the computer indicates that its battery is charging. Usually there's an LED (light-emitting diode) that flashes when the battery is charging. If you can't test the power supply using this method, take your notebook computer to a technician who can test the adapter.
My laptop charger is not working
Two possible causes:
1)your laptop charger is dead or malfunction
2)your laptop dc jack is loose or malfunction
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
http://www.chargerbuy.com/replacement-toshiba-satellite-m30-ac-adapter-15v-5a.html
Nov 21, 2012 | Toshiba Satellite M30-832 Laptop Charger...
Toshiba satellite m30 bios password
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Jan 11, 2011 | Toshiba Satellite M30-S350 Notebook
Switch on wireless key on Toshiba Satellite M30,
Try downloading and reinstalling the drivers for the wireless network adapter. If you have the original disk it should have the driver if not you can download it from the Toshiba site.
Jan 07, 2010 | Computers & Internet
Experts@fixya.com
its possible that you have the presentation mode turned on.
press the F5 key and the Fn key together
you might have to do this several times
this should fix the problem. Hope it helps!
Feb 01, 2009 | Toshiba Satellite M30 Notebook
Toshiba m30 satelite screen problem
I would suggest you contact a local service tech and have him take a look at it sounds like you have a serious connection problem, or a defective motherboard.
Dennis
Jun 19, 2008 | Toshiba Satellite M30 Notebook
Power on password for toshiba satellite m30-107
You can by shorting the CMOS/BIOS battery connector for 30 sec's with a resister pack (2.4 KOhms), but if you don't have any PC repair experience, don't try it!
"You can blow the motherboard if you get it wrong.."
I suggest you take it to a Toshiba repair shop, it will cost about $100 to have them do it for you.
May 08, 2008 | Toshiba Satellite M30 Notebook
Background has turned 90 degrees
You can flip the screen around by holding down
CTRL + ALT AND ARROW KEY
CTRL + ALT + right
CTRL + ALT + left
CTRL + ALT + up
CTRL + ALT + down
with these keys you can flip the screen around as you want. Noting serious.
Toshiba Satellite M30 Montior Blackout
have you tried changing the resolution, if not try this power on your laptop press F8 run in safe mode go to device manager an disable your display adapter after disabling reboot windows after rebooting go back to device manager enable display adapter and go display properties an change resolution.
Mar 15, 2008 | Toshiba Satellite M30 Notebook
Toshiba Satellite M30 Notebook Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
