Question about Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher
How to install dishwasher your self
How do it yourself install a dishwasher
  • 6 more comments
  • Anonymous Mar 02, 2008
    Can someone send me a manual for this machine? Thank you!
  • sugrdad_e Apr 29, 2008
    Need an install manual. HELP! Galaxy 24" white dishwasher. please email me.
  • Anonymous Aug 08, 2008
    Did not received the owner manual need to know how to install and how it work
  • Anonymous Oct 14, 2008
    how to instal
  • Anonymous Nov 08, 2008
    white admiral
  • W_RIVERA2007 Jan 28, 2009
    Can i have the Installation Manual for a Kenmore 587.15142400 Dishwasher machine? Please help me..
    Email w_rivera2007@yahoo.com
    Thanks
  • shorty22 Feb 10, 2009
    I need to know how to install this dishwasher I have no idea how to do this so please help.
  • W_RIVERA2007 May 11, 2010
    I found the manual, thanks
  • 49 Answers
If you can provide an email i can send u an install manual
Posted on Feb 19, 2008
What does E24 mean
try to display also your model no. it could be something different.
E24 Drain filters blocked. Clear the filters. Generic instructions to clean your dishwasher filters is available from here.http://www.ukwhitegoods.co.uk/help/fix-it-yourself/dishwasher-self-help/2813-dishwasher-general-care-a-maintenance.html
Dec 11, 2013 | Bosch Dishwashers
WASHING MACHINE SHOWING ERRORMESSAGE 5E
rw
Hello, and sorry to read about you 5E code issue.
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
If your hose shows no kink's you may have a clogged pump.
I have tried to help you. PLEASE rate/vote the response. we take the time to respond to you. take the time to rate. Thanks and good luck on your problem.
Dec 24, 2010 | Samsung WF306BHW High Efficiency Front...
I have 5E showing on my dishwasher. What is does this error mean?
ost common error codes that are caused by installation errors are:
  • 5E. If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
  • Info provided by Articlead.com
Dec 09, 2010 | Samsung DMR57LF Builtin Dishwasher
Self Cleaning filters are not cleaning themselves.
Pl check the over-head tank of your premises. Clean the tank.
Alternatively you can install a master filter in a accessable level( height ) for the easy cleaning. There are no self cleaning systems. If the filter is removed it will go and clog the out-let valve and you will end up in more maintenance cost.
Apr 29, 2010 | Maytag 24 in. MDB9150A Built-in Dishwasher
Bosch built in dishwasher shu4302uc The dishwasher appears to run through the cycle but the cycle takes over three hours. When the cycle finally finishes the dishes are not completely dry. Is there a way...
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
Feb 22, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Is there an old dishwasher where you are installing the new one? It must be connected to a water line, a drain T and an electrical connection. If you have never installed a dishwasher before, it would be a better idea to have someone install it for you (preferrably a licensed installer) or you could have leaks or other problems down the line.
Feb 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher Logo
359 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
