Question about HP OfficeJet 6110 All-In-One InkJet Printer
How to Disassemble HP Officejet 6110 for cleaning
I have the same "grinding" problem with a print head that keeps moving back and forth and not working that other people on here describe. Every solution talks about cleaning the glass, however, they don't tell you how to actually lift the top frame off to GET TO the glass. I'm not talking about the little strip of glass on the left, I'm talking about the Big Enchilada, giant piece of glass that covers the top. I've gotten as far as undoing all the screws, taking the left strip of glass off and the front button panel completely off. It LOOKS like the plastic frame around the glass should lift right up -- except that IT DOESN'T. I am at my wits' end...would someone please instruct me from here???
  • 3 more comments
  • medlawcat123 Feb 16, 2008
    I already did it on my own, thanks. I asked for a solution, not for someone to send a belitting response.
  • Beniamin Feb 19, 2008
    I need to clean the other side of the scanner glass, and I am at this same point---I have unscrewed the screws from the scanner bed, taken the front control panel off, and now I can't figure out how to make the whole thing let go when I lift it!
    I did a search for the "service manual," but came up with nothing. Any advice?
  • twanprive Sep 12, 2008
    I did 6 steps but how to lift the front?
  • Anonymous Mar 24, 2009
    oh wd40 mine does the clunking and grinding took aprt everything looks good must be a logic control error
  • James F Roberts Nov 19, 2011
    Could you please share how you did it so we can learn?
I had a problem when i started up my printer the scanner would go out about half-way to the end and when it comes back it woyuld make a sound as if it where stuck. so what i did was i completely disassembled it. if anybody has any questions then just let me know
Posted on Mar 18, 2009
I had the same problem yhe carrage went to the end and just banged i sprayed wd40at the end and it works well
Posted on Mar 19, 2009
    Genius:
  • 3,587 Answers
I'd be remiss in suggesting that this is that simple. The service manual shows a seven step process for removing that glass. You sure you want to mess with that?
Posted on Feb 16, 2008
  • Patrick Michaels
    Patrick Michaels Feb 16, 2008
    there's always one in the crowd, isn't there Mr. Jackson?
  • Amonptah Maat Aug 20, 2016
    Hi Patrick,
    Mike here.i would like acquire/purchase the service manual,or other reliable instructions to disassemble/reassemble the printer; can you assist me?
    i want instructions to disassemble the printer in order to replace the ink carriage assembly( this is the unit that hold both ink cartridges) ; hp corp doesn't have it any more /out of print. I don't need the reference manual/ user guide,nor the trouble shooting guide.
    Problem Solver:
  • 14 Answers
Fiend your solution direct from Hp. Here is your solution....
http://www.hp.com/printer/prob676ijt65/solution
In Hp officejet 6110, when i am printing then it come dark and lining is coming plus to print its take long time. need soluation.
Your printer head must be dirty and needs to be cleaned. Try going to your printer application and look for the option for maintenance. If you cant find it, you can go to control panel, printers and faxes, then double click on your printer model. It should take you to your printers menu, just look for the option to clean it. Print a test page after cleaning. If you still see lines, just repeatedly do the cleaning until you no longer see the lines. If it still doesn't work, you can contact HP.
Apr 05, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 6110- do display/needs attention light on continuously
try this
turn on/off, unplug, plug in, should reset configs. might have to do this a coupe of times
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
hope this helps and good luck
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Printer is not printing anything at all..black or color. Cartridges travel back and forth and paper is pulled into the printer just like it is going to print. But, the paper comes back out completely...
Make sure the sealing tape is completely removed from the print heads (the silver part on the bottom of the cartridge). Then press the print head against a paper towel to get the ink flowing. If that doesn't work, try cleaning the cartridge electrical contacts in the printer and on the cartridge with isopropyl alcohol followed by water.
Dec 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 430 plotter
does the belt look ok? sounds like you have some rubber stuck in the motor gear.
Oct 22, 2009 | Office Equipment & Supplies
My HP 66110 will not start up. There is a grateing sound when on button is pressed, there is no paper jamed in system.
Try unplugging the printer and opening the door where the printing heads are, and make the sure belt that moves the print carriage back and forth is not broken or damaged. Pull the belt so that the print carriage is moved to a different position than where it usually parks, and that may unjam or reset the mechanism. The grinding sound might be coming from the scanning mechanism, or the scanning sheet feeder. Try manually turning the wheels for the feeder and make sure they turn.
Sep 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The printer is making a gear clicking sound.
I had exactly the same problem with my OfficeJet 6110 as reported above (i.e. the scan head not knowing where the end-stop is). This is how to fix it (this method worked for me) 1) Lift up the scanner/copier hinged lid. Around the edge of the scan glass are 4 Torx screws. Undo all four screws. 2) Carefully prise the control panel faceplate off. The buttons underneath are on a single panel. Slide this to the left and lift off. 3) Jiggle the lid of the scanner to get it off the main body of the printer. 4) Locate the scan engine motor (top right corner) and remove the two motor retaining screws (one on the left of the motor, the other on the right). 5) Lift out the entire mechanism (rod, drive belt, scan head) and turn over. 6) Thoroughly clean all glass and mirrored areas of the scan head. Also clean the scan lamp on the top of the scan head. Clean the tray inside the scanner (where the scan head travels back and forth). Also clean the inside and outside of the scanner glass pane itself. 7) Refit all parts, using the technique described above, in reverse order. 8) Switch on printer. It should now work OK. Hope this helps, guys.
Jun 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Make grinding noise
If you will notice that there is a transparent film that the printhead goes through to be able to print. That transpatent film is actually coded to be able to tell the print head in which direction and when to print characters. It is dirty and you need to take like a q-tip with isopropyl alcohol to clean it so it knows where to print and does not go back and forth to find a position to print. God bless you.
Jan 12, 2009 | HP Officejet Pro L7650 Printer
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
2,144 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
