Question about Refrigerators
Ge Refrigerator will not despence water
How can I test the valve that controls the water flow?
  • 770 Answers
To the icemaker or the water dispenser??..you will need a meter both should have 120vac at the valve when enegrized.. (by the IM or the Disp) it is a dual valve
Posted on Feb 16, 2008
No water coming out of valve in back of refridgerator when button is pushed\
Warning you may have to test electrical circuits with the power live .Is there water flowing into the connection on the unit ? If not look for shutoffs or a crimped supply line. If you have water pressure You will need to know how to an electrical tester or multi meter to test the water inlet valve. You can test for voltage on the solonoid while someone activates the switch for water If you have voltage when the switch is activated the inlet valve could be bad or the tubing feeding the dispenser is frozen or pinched you can loosen the water line that goes to the refrigerator to check for flow with switch activated If you have no flow replace inlet valve if you have flow check that the waterline is not frozen crimped or pinched.If no voltage appeared during the voltage test , Test the switch and wiring and repair as necessary.
Aug 02, 2014 | GE GSL25JFXLB (250 cu ft) Side by Side...
How to shut off water on GE ZIS480NR
If water continues to flow without pressing the dispense button or the water continues to flow into ice maker the cause is most likely a defective dual water control valve. The correct replacement for your ZIS480NR is=> WR57X10032 Dual Water Control Valve.3_6_2013_7_57_28_pm.jpg
I will be here should you have questions, Thanks Sea Breeze
Mar 06, 2013 | GE ZIS480NR Side by Side Refrigerator
Water will not flow into ice maker
Not typical for both sides of your=> WR57X10032 Dual Water Control Valve
but this is possible. You will need to do some testing of the control valve found at the link above or HERE If there is no problem with the part then you will need to turn water off and disconnect water line feeding the refrigerator. Place the water line into a bucket and have someone turn water back on so you can see if there is something blocking or restricting flow to your refrigerator. I will be here to answer any questions you may have, Thanks Sea Breeze
Here is a manual=> GE Refrigerator Technical Service Manual
Let me know if you would like my assistance, Thanks Sea Breeze
Nov 05, 2012 | GE Profile Arctica Stainless Steel Top...
Water won't come out of dispenser. ice works fine
Your refrigerator is equipped with a dual water inlet solenoid valve assembly . It is likely that the solenoid valve that controls flow to the water dispenser is faulty. Click here for a tutorial on How to Test Inlet Valve.
Feb 11, 2011 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Side by side model number TFH22PR. Works great, but ice maker not working. It produces water from door just fine, but no ice. What's up with that? Clogged somewhere?
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | GE Refrigerators
Water dispenser sticks open on model TFX25ZPBEWW
If you unplug the WR57X10026 Twin Water Control Valve on the rear of the refrigerator near floor will the water flow stop. Then plug that back in and unplug the refrigerator doest the water stop? I need to find out if the water control valve on the rear of the refrigerator is leaking while turned off or if the dispenser control board is sticking with the power turned off. Your model comes with 2 different choices of water control valves.let me know Thanks, Sea Breeze
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a fridgitarie side by side we want it to despence cube, but only get crushed, even when we have cubed light on
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 29, 2009 | GE PSS26SHRSS Side by Side Refrigerator
GE model GSH25JFTACC ice maker not working
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
KENMORE REFRIGERATOR 106.57024601
the problem is most likely the water valve behind the machine. it is closing too slow and letting too much water flow into the icemaker. c30b276.jpg
Jul 16, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
