Question about Yamaha RX-V661 Receiver
No zone 2 sound coming from yamaha amp rx-v861
Hello, I hope you can help me,after reading the manual several times over,i cannot understand how to set up the rxv861 receiver amp to use zone 2 outdoor speakers.could someone please put in simple laymans terms( inc speaker wiring to the amp) from very start to very end via menu instructions how i can do this, as i am an absolute beginner.Please disregard product description below,Thanks very much in advance.regards Steve
  • 1 more comment
  • Anonymous Feb 17, 2008
    I am trying to do the exact same thing with my RX-V661 and having sinilar troubles. I can't seem to get to the menu "ExtraSPAssignZone2>FrontBPresence" which the manual says to do if you want tuse Zone2.
  • Anonymous May 30, 2008
    I have the same issue. can hear speakers outside, but cannot get zone2 to control their input or volume. zone2 shows that i change the input, but it doesn't really change and any volume changes for zone 2 result in "VOL FIX". The strange part is that I had this working before, but just can't remember what I did.
  • cekeagy Apr 19, 2009
    We can't get any sound to come out of the wireless speakers attached to zone 2 when we select them, even though the speakers are picking up signal from the transmitter.
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Posted on Jun 22, 2010
    Genius:
  • 1,175 Answers
Does this unit have A / B speakers select?
Posted on Feb 24, 2008
It sounds like your amp setting needs to be changed. Go into your options menu i believe and go down to zone 2 and go into that menu and make sure the amp setting is for INT not EXT as you're using your receiver's built in amp in zone 2.
Posted on May 29, 2008
    Problem Solver:
  • 4 Answers
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Posted on Aug 04, 2008
No volume from surround sound system on dtvcbl cable, dvd or cd modes with yamah rx-v861 powered on.?
Have you looked at the manual? How did it fare using the set up test tones? Did you assign the digital inputs?
http://www.retrevo.com/support/Yamaha-RX-V861-Receivers-manual/id/2526ci757/t/2/
The unnamed sources probably have manuals, too.
Apr 26, 2011 | Yamaha RX-V861 Receiver
Please how do you restore factory default settings on a Yamaha RX-V861 receivers ?
Hello
the hard rest method is usually to unplug the unit for about 15 minutes. If this doesn't work, you can download the manual HERE.
Hope this can be of help.
Kind regards
Andrea
Aug 13, 2010 | Yamaha RX-V861 Receiver
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
I have a Yamaha RX-V1400. Can no longer select ZONE 2
check the setup menu in the receiver to reset the outputs for zone use instead of 7.1 use
Oct 17, 2009 | Yamaha Audio Players & Recorders
Have no sound when I connect the rear speakers
Open the "Menu" on screen, go to "manual setup" then "speaker setup" check your settings on "surround rear" and "surround back" If your not using zone 2 and zone 3, in the menu for zone 2 amp, select "Ext" and "Ext" for zone 3. If you still have an issue, post a comment and I can help you some more. I am a Yamaha Dealer. Hope this helps
Jul 03, 2009 | Yamaha RX-V1800
Hooking up a Yamahoa RX-V861 without a manual
If you jump on the Yamaha web site you can download the manual which will show you how to connect the speaker system. Hope this helps.
Regards
Nov 17, 2008 | Yamaha RX-V861 Receiver
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V661 Receiver Logo
4,002 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
