Question about Refrigerators
Refrigerator not cooling
Interior light is on, but NO other activity. Unit has been colder than usual for 3 days ( freezing in refrig compartment), Turned it down one notch. Seemed ok today. Tonight, I found food thawing in freezer. Turned temp control up.
NO response. No icing around evaporator coils.
Hotpoint CTF 21 ERR
  • Gianni Magnani Feb 16, 2008
    I smacked temp control. Nothing.
    I turned defrost control. Nothing.
    I turned the temp control to "off." Unit suddenly came alive.
    Temp in freezer is now 10. In fresh food, it's 38. BUT if I turn the control, even a hair away from "off," towards temperature settings,
    it turns off.
    What's next?
    President:
  • 1,314 Answers
You need to locate the defrost timer should be in the same box the temp control is some have little knobs some have funky little screw heads like the screws in bathroom stalls should be a hole in the housing where the thermostat is turn it slowley clockwise till you hear thu unit come on if it before you do that smack the temp control first a couple of times make sure its not sticking then let me know
Posted on Feb 16, 2008
  • robert samples Feb 16, 2008
    replace the control you said it your self its acting funky and leave it alone for now just get the model number go to an appliance repair store and unplug the fridge before in stalling the new one now i imagine next things in the fridge will start freezing till you replace the control hey another block wold be nice lol it helps me for the people i reply to but dont answer back i got 324 so far that didnt brother thanks for your reply
My TRUE GDM49 refrigerator is freezing food...what do i check or replace?
HI,IF YOUR REFRIGE IS FREEZING IN THE REFRIGERATOR COMPARTMENT EVERYTHING ,CHECK THE AUTODAMPER OR AIRFLOW CONTROL FOR ICE BUILD UP ,NOT LETTING THE DAMPER TO CLOSE ONCE IS COOL ENOUGH IN THE REFRIG SIDE,MOST OF THE TIME WHEN REFRIGERATOR IS FREEZING TOO MUCH THE AUTODAPER IS BAD.GOOD LUCK..
Feb 21, 2011 | Refrigerators
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool...
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Aug 21, 2010 | GE GSH22SGRSS Side by Side Refrigerator
I have a problem with my refrigerator not cooling consistently. It seems like at least once a day it will start warming up but the compressor doesn't come on. When I turn the temp up control nothing...
I believe this is normal behaviour in all auto defrost (which means virtually all modern) fridges. In fact, this short heating period is usually programmed to happen 2 to 3 times a day. You might rightly ask why the refrigerator compartment needs to undergo "defrost" cycles when the compartment is, if the refrigerator is operating correctly, above freezing? The reason is although the compartment is above freezing, its cooling coils are well below freezing temperature, and it's these coils that need the frequent defrosting, before they build up so much frost on them that they "ice up" and no longer allow the fan blown air that cools the refrigerator compartment to pass through them.
Nov 12, 2017 | Kenmore Refrigerators
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
Refrigerator freezing lettuce. Adjustments result in freezer section too warm. I can't seem to find the correct settings. I can't locate my manual. This appliance is 25 years old or more.
a refrigerator thermometer is a good investment (usually available at grocery stores) .. i have two to make it faster to adjust things (one in freezer and one in refrigerator) ... first set the freezer with the temperature control .. set the freezer to 0 degrees F (adjust a little at a time until its close (wait several hours or a day between settings) ... then you may have another control called "air" or "refrigerator" .. you set that one for 37 deg in the refrigerator .. it usually takes a few days to get it right .. but without at least one thermometer you are flying blind, its nearly impossible to do correctly .. you can use any thermometer that is accurate down to 0 degrees, so you dont have to buy one if you already have one .. once you get it right you might want to mark the adjustments incase someone changes them ..
Nov 21, 2009 | Televison & Video
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerator won't get cold
hi!, if you did not turn on the thermostat by turning it clockwise and set on highier setting, it will not getting cold. 1hr is enough to test if the unit is in good condition.
Nov 19, 2007 | Samsung RF265AA Bottom Freezer French Door...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
214 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
