Question about Dell Inspiron B130 Notebook
I can't turn on the laptop. How can i restore the system?
  • 58 Answers
For XP: turn the computer, on the dell splash screen, hold down CTRL then keep tapping F11.
For Vista: Just keep tapping on F8.
Posted on Feb 16, 2008
How to restore my computer to factory?
In order to restore your system, follow the steps mentioned below:
    1.Turn on or reboot your laptop.
    2.Press and hold "Ctrl-F11" for two seconds when the Dell logo appears on the screen.
    3.Release both keys simultaneously to launch the Dell PC Restore window.
    4.Click "Restore," then click "Confirm" to begin the process. Allow approximately 10 minutes for the restore to complete.
    5.Click "Finish" to restart your laptop. The operating system and computer files are now restored back to the original factory settings.
    GuruAid.com
Jun 01, 2014 | Dell D600 Laptop
My dell laptop (latitude 2120) caps lock button keeps blinking and my laptop can't turn on?
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 07, 2013 | Dell Latitude 2120 Notebook
My Toshiba NB200 doesn't want to boot. I already press f2 or f12 but it only said Please wait but it did not continue. I turned it on and off also but to no avail. What could be the problem?
There is a possible corrupted files on the system that is why your laptop won't boot up. You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the laptop. If the laptop will still not boot, turn if OFF again and keep tapping F8 upon turning ON to enter safemode. In safemode do the system restore. You will find the system restore in start/all programs/accessories/system tools/system restore. Select the previous date that the laptop was working fine. If will not work, the last option is the recovery. You may access the recovery partition by hitting 0 upon turning ON. But this procedure will reinstall the factory settings, meaning, it's like starting from scratch again.
Mar 23, 2011 | Toshiba Computers & Internet
I done a norton scan removed the virises now its logging on then straight off cant get into mt laptop
Turn system restore off to begin with. Not sure how familiar you are with this process but click on start, then right-click on "my computer", then click properties, then look for "system restore"...should be top left tab. I'm assuming you are running windows XP? Anyway, put a checkmark in the box that says "turn off system restore".
Now run your full system scan with Norton. Whatever Norton detects and removes etc...it will now be vanished since the virus can no longer back itself up in the system restore file.
Godspeed! It's a time-consuming process for sure. Best of luck!
Jan 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
Computer will not allow me to restore previous settings
go to start, then accessories, then to system tools..and then restore...if this dont work u can always restore settings by hand and create a new restore point...gl
Nov 21, 2009 | Acer Aspire 5100 Notebook
Blocked out my laptop!
Do the following to restore it.
1. Go to Start Menu
2.Click on Run
3.Enter the following %SystemRoot%\system32\restore\rstrui.exe
4.Click Ok
5.Click on the Welcome to System Restore page that you will see
6. Create a restore point
7. Click Next
8. Give a name to your restore point
9. Click on Create
10.Close after the restore point has been created.
Note: If the system restore point is turned off, clear the check box in the system properties dialog box and click ok after you are done.
Regards
Sep 24, 2009 | Computers & Internet
Missing files and photos, settings ect
Log in as Administrator and undo the system restore.
How to undo a system restoration after you perform a System Restore loadTOCNode(2, 'moreinformation'); You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
  5. Log on to the computer as Administrator. The System Restore Undo Complete page appears.
  6. Click OK. You can now run System Restore again from a different restore point.
Dec 16, 2008 | Dell Inspiron 1501 Notebook
Need to Restore My Acer Aspire 5315
Turn on your laptop...as soon as it turns you push thepower botton start pressing F8, this will take you to the system recovery screen. You will need to pick the option that says system restore. Dont pick the option that says restore to a restore point, you will need to pick the one that say destructive restore. usually u get this option by pressing the advanced options. It will give you a warning about the system being reformatted...are you sure...yada yada yada... click ok and it should reformat the system and then reinstall the original facotry software
Nov 09, 2008 | Acer Aspire 5315 Notebook
SYSTEM RESTORING FOR HOURS
Stop trying to restore, turn off the machine, wipe the hard drive, reload the operating system, open the window and toss Kapersky.
Jun 21, 2008 | Dell Inspiron 6000 Notebook
System Restore gets disabled
You must set the "Service" to "Automatic" here are some instructions. And a link to a M$ KB article about it. support.microsoft.com/kb/302796 Start the Group Policy Editor (gpedit.msc) Navigate to Computer Configuration/Administrative Templates/System/System Restore Set Turn off System Restore and Turn off Configuration to "Disable" Right click on My Computer and Select "Manage". Navigate to Services and Applications/Services Navigate to System Restore Service and double click On the General tab set [Startup Type] to "Automatic" using the drop down list Click the Start button to start the service. Close the Computer Management console Return to System Restore in Group Policy Editor and configure both to "Not Configured" Close Group Policy Editor and reboot the system. After the reboot is complete, right click My Computer, select Properties and the tab for System Restore will have been restored. Configure it to your individual needs.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Dell Inspiron B130 Notebook Logo
24 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
