Question about Jl Audio 250/1 Car Audio Amplifier
Added another amp to system now subs dont hit as hard
I have the JL Audio 250/1 hooked up to 2 kenwood 10s... and i had my full range infinity kappas just run straight from my radio. the problem is i recentelly installed a 2 channel amp to power my full range speakers but when i did this i lost how hard the subs hit... i added a capacitor to the power cable for the JL amp, and even ran a whole different power wire from the battery to the other amp to keep them seperate but my subs still arn't hitting as hard as they did and i even went as far as unhooking the other amp so just my JL would have power and they still didn't hit as hard... so please if anyone has any suggestions id love to hear them i want my subs back...also if it helps, both amps have seperate audio cables run from the back of radio
  • tylert2490 Feb 18, 2008
    Actually i corrected the problem, i tilted the sub box over to make some adjustments on the amp and when i did so they totally stoped playing, so i messed with the audio cable and come to find out it was no good, it must have moved at some point in time and just happened to be the same time i put in new amp, so i replaced it and they hit just as hard as ever, thx for the advice tho.
  • 65 Answers
This sounds odd, but try putting your subs out of phase from the mains. Just see if it changes anything.
Posted on Feb 17, 2008
I have a kicker zx350.4 for door speakers and the amp keeps cutting off once the bass hits hard or i have it aloud , once i put the volume down or bass low it comes back to normal and amp doesnt get hot at...
kappas are 2ohm. You are running that amp at 2ohms stereo on front and rear channels. That is a nice amp, but it is a thirsty one. If you have a sub amp as well, then you are not supplying your amps with enough power. drop down to 0 gauge and see if it heats up anymore. Also, try going high pass if you have subs. If you don't have subs. You need to run 4 gauge and make sure you have a great ground.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 31, 2014 | Car Audio & Video
Hi i just got 2 new infinity 860w reference 8'' subs 250 rms each and pushing it with sony 600watt amp pushing it but very low sound and no bass why the othier speakers i have in 10'' hit the bass fine but...
The amp may no thav eenough to push these subs, these are top of the line subs, they probably require a bigger amp, if you are running other speakers through this also, you certainly need another amp, or a bigger one with more channels. also double check all your wiring.
Mar 29, 2011 | Jl Audio 12W7 Car Subwoofer
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
Loud with one quiet with both
make sure you have seperate power and gound seperate remote wires and if it does have a pass through then use it but i would hook up one at a time make sure they both work if after all this and it dont then your deck may not have enough power coming out of it to power the rca's or use y adapters from the cd player and run 2 sets of rca's.
Apr 05, 2010 | Kenwood KAC-7201 Car Audio Amplifier
Why doesnt my jl 1000.1 pick up my 13.5w7
ohm load check the way you wired it if the amp can handle 1ohm make the sub 1 ohm dule 2 ohm subs hook the neg from one coil to the pos on the other then take the empty neg hook it bridged to the neg on the amp and empty pos to the pos on the amp also check to see if you hooked it up bacwards subs dont hit hard when they are beating in and not out
Feb 06, 2010 | Jl Audio 13W7 Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Car audio
mike, this is a beautiful and perfect setup! if you dont have a headunit yet i know the #1 perfect one for you CLARION DRZ-9255 .http://www.clarion.com/us/en/products/2008/audio/source_units/cd/DRZ9255/us-en-product-pf_1172385113235.html i have owned every single piece of equipment that you have! my set up was the same exact way except i used focal utopia 33wx for my subs. but JL AUDIO are the masters at making the best subs for the money by far! i have owned every line of subs JL AUDIO has ever mad,my overall favorite. sean314 623 7054 cell
Sep 11, 2008 | Focal Utopia Audiom 6W Car Mid-Range
Jl audio 250/1
ok what is the amp out put of your altanator and were did you hook the romte turn on wire two. It is usally blue.
Jul 20, 2008 | Jl Audio 250/1 Car Audio Amplifier
One of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Apr 09, 2008 | Jl Audio 12W3 Car Subwoofer
Jl Audio 250/1 Car Audio Amplifier Logo
199 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
