Question about Samsung LN-T4671F 46 in. LCD Television
Blue tent while playing movie
I have a samsung flat panel tv. when i play a dvd the color seems to change to blue, like all other color is lost. but if i play a vhs or watch tv the color is fine. whats wrong?
  • Oli Gee Feb 29, 2008
    I have the same problem with a Samsung LE37 have you found the solution?
It seems to be something wrong with the processor as it sometimes 'resets' when you turn the TV off and then back on again.
Posted on Mar 16, 2008
  • 29 Answers
What type cables are hooked to the dvd, check and make sure that the cables are seated properly or chang the cables , could be the dvd player also
Posted on Mar 15, 2008
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
I have a two year old lcd samsung tv which now has vertical lines. What are the causes?
try to play DVD movie or video when the problem still there the possible cause is T-con board if no vertical lines when you play DVD your tv is good your problem is on the loose connection
Sep 24, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Tv as a whole is working but display keeps changing into excessive red then blue then green then normal then again the same in a few seconds. please provide solution
Good day!
Try to play a movie using DVD players to determine if the TV have a problem or not.If the movie you play is normal and not changing color.Your TV is in good condition and the problem is in aerial antenna or on the cable.If you are using aerial antenna you have to relocate it on the place with high signal,it is usually on the top of the roof.And if you are using a cable,please contact to your cable service hot-line.
Thank you and good luck.
May 06, 2011 | Televison & Video
Panasonic TC-P42U1 plasma. Lost it's vivid colors basic color is black and white and green and blue if tint color tone etc. Is turned up. However a blue ray video plays with full color. Could it be a lose...
I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
Jun 27, 2010 | Panasonic TC-P42U1 42 in. Plasma HDTV
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
No color on output of dvd movie
check for yourdvd system setting
Sep 20, 2008 | Televison & Video
DVD'S will not play..
Sounds like the unit is bad, or set to the wrong Regional Code. Its not easy to set the regional code and it varies by model. You are better off buying a new DVD player given they can be found for under $30.
Aug 28, 2008 | Samsung DynaFlat CXM2785TP 27 in....
Color of people's faces in movies played via DVD is now blue since connected to LCD TV
The reason the picture is blue on the DVD is because you have poor video cables running the feed, probably RCA yellow cable im guessing. Get some nice component cables for the DVD feed and it will fix you right up.
Dec 26, 2007 | Televison & Video
Playing ps3
go to bd/dvd settings.scroll down to 108024ghz.Change it to "OFF" not "auto" and not "on"this should do it.
Aug 04, 2007 | Samsung LN-S4695D 46 in. LCD HDTV
Samsung LN-T4671F 46 in. LCD Television Logo
113 people viewed this question
Jerry Greenberg
Jerry Greenberg
