Question about RIM BlackBerry 7100G Smartphone
Blackberry 7100g cell phone
The connect option is not displayed in the bluetooth: enabled screen menu on the
  • Anonymous Mar 24, 2014
    my 8220 keeps telling me that bluetooth is disabled.
    I act enable it.
  • 3 Answers
I don't remember how i connected mine, check directions that came with the bluetooth. i think i turned the bluetooth on first, then add device. i know you need a # from the bluetooth to put into the bb. usually 0000 or 000 (cant remember) for motorola.
Posted on Apr 19, 2008
How do I use the loud speaker on a Blackberry pearl?
Hi there
Although the Blackberry pearl does not come with a speakerphone, you can still set up this function by using a Bluetooth device.
HERE IS WHAT YOU SHOULD DO
Power on your Blackberry using the On/Off button in the lower right-hand corner of the device
Turn on Bluetooth
Find the Bluetooth option. In the main menu, select "device options."
Enable Bluetooth radio. Click on the trackwheel to scroll down until you see the option "Enable Bluetooth". Select this function (click the trackwheel) to turn on Bluetooth compatibility. If you have completed this step correctly, you will now see a "Bluetooth icon" on your Blackberry screen. If you want, you can later turn off Bluetooth by repeating Steps 1 to 3 and then selecting "disable Bluetooth".
Pair your Blackberry with a Bluetooth speakerphone
Power on your Bluetooth speakerphone device using its On/Off switch or button.
Find the Bluetooth option in the main menu by again selecting "device options" and then using the trackwheel to scroll down until you see Bluetooth. Select this by clicking the trackwheel.
Add your Bluetooth device. Click on the trackwheel to scroll down until you see "Add Device." Then click on the trackwheel to select this function.
Enter the name and passkey of your Bluetooth device. When prompted, scroll down with the track wheel until you see the name of your Bluetooth device. Your Blackberry automatically detect your Bluetooth speakerphone if it is within 10 meters. If it does not, enter the name of the device, then type in the passkey provided by the manufacturer of the speakerphone.
Enter the passkey on your Bluetooth speakerphone. Your Blackberry and Bluetooth speakerphone can now communicate with one another.
To use the speaker during a call all you need to do is;
Dial a number and hit the send key. Make sure that your Bluetooth speakerphone is on, and that you have already set your Blackberry to "Enable Bluetooth." If you see the "Bluetooth icon" you have already done this step.
Activate your Bluetooth device. When the call has connected, click on the trackwheel until you see the option "Bluetooth Device". Then click on the trackwheel to activate the Bluetooth function. Your Blackberry will now route your call to the Bluetooth Speakerphone.
Turn on the speakerphone. Depending on which Bluetooth Speakerphone you have purchased, you may need to click on the "speakerphone" button to enable this function. Once the speakerphone is on, you may continue with your phone call.
Sep 19, 2010 | Cell Phones
How do i turn my bluetooth on and reieve songs
Turn Bluetooth ON or OFF on BB RIM:
1. From the Home screen, press Menu.
2. Click Options.
3. Click Bluetooth.
4. Press the Menu key.
5. Click Options.
6. Set LED Connection Indicator to On or Off.
7. Press Menu.
8. Click Save.
Using the other phone, or other device, search for the available Bluetooth device in range. The BB should be detected or found. Then, pair the two devices and connect. Once the two devices are connected, select a song from the source device, and find the option to send the song via Bluetooth.
Thank you!
Sep 11, 2010 | RIM BlackBerry Storm 9530 Smartphone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How do i connect bluetooth
Please try this simple steps
1. From the BlackBerry smartphone home screen, select the Options icon.
2. Select Bluetooth.
3. Highlight the Bluetooth and press the Menu key enable it.
4. Select ADD devices option and then connect..
I hope this information is helps
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
I have a Blackberry 8310. When I try to connect
go into bluetooth setup screen and hit options, make sure BB is set to discoverable. Then hit menu again and choose "add device".
Aug 21, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Blackberry Service Book
If you go to the Manage connections , you can enable Bluetooth in that screen, and thenset up the bluetooth connectin as well.
Hope that helps, if if did please rate my solution accrodingly. Thanks, David
Mar 18, 2009 | RIM BlackBerry 7100G Smartphone
Blackberry pearl 8130 issue
restart the phone then try again or take the phone to a mobile store and ahve it check
Sep 19, 2008 | Verizon Communications BlackBerry Pearl...
Blackberry pearl 8130 issues
take the battery out of the phone then place it back in the phone and try again, if it freezes again then you have a software problem and you will need to take the phone into a repair center and have it diagnosed.
RIM BlackBerry 7100G Smartphone Logo
57 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
