Question about Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 service menu
Anyone know the correct entry code, for entering the service menu on my sharp dlp ,threw the remote
  • Anonymous Jun 17, 2008
    humming
Hold menu & vol+ (for 3sec) opens the lamp counter reset menu on Sharp DLP
press OK to reset
Dan
XPortHomeNetworks.com
Posted on Aug 16, 2008
Celcus led22167fhddvd tv has menu lock enabled. When I press the menu button the screen asks for the pin to be entered. Tried pressing the correct numerical buttons to enter this but tv doesn't seem to...
hellllllllo.........don't know if you did this ....i goggled operating instructions for this model its there .....i understand if i had the remotein hand.......tkx........g.scott
Oct 11, 2014 | Televison & Video
Service menu
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Service mode entry, adjust and exit procedure to many popular brand TVs are given. Before entering service mode, a close look at the procedure is necessary, because, you have to exit from the service mode, after entry. In service mode, a few buttons on the front panel of the TV, and remote controls will only operatabe. If you want to operate all the button function, as it was, have to exit this mode.
Dec 24, 2013 | Disney PC1310ATV 13" TV
I have a new sharp aquos tv LC 60LE633U. Remote is broken but have a universal Phillips remote anyone know the code ? Help please
Hello
Three digit universal remote codes for Sharp tV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 28, 2012 | Sharp Televison & Video
I need the code for an RCA remote model RCR311W for a sharp tv
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Mar 04, 2011 | Televison & Video
I need the codes for a Sharp Tv for my Big Matters Jumbo Universal Remote. Can you help me?
here's the codes to your sharp tv for that remote
Sharp TV:
013, 028, 035, 073, 075, 078, 092, 093, 120, 131, 132, 134, 139, 141
1. T urn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (just try one of the codes I listed above) if one doesn't work just try the next one,
3. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the POWER button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Feb 28, 2011 | Televison & Video
My TV model 21QF2-A is locked please send me unlock code. thankyou
my sharp tv model 21qf2-A asks for a code or password of 4 numbers that I forget. What should I do?
Nov 24, 2010 | Sharp 32C-240 32" TV
I have an old 13 inch sharp TV with no remote but do have a One For All Access 4 remote. I need the 4 digit code for the Sharp
I can help you with your URC-1050 Universal Remote Control issues.
The URC-3220 codes for Sharp TVs are: 0093, 0165, & 0688.
For complete instructions on entering the URC-1050 remote codes, please refer to my posted Fixya Tip One For All URC-1050 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-1050 Manual
One For All URC-1050 Code List
One For All URC-1050 Code Search
One For All URC-1050 Reassign Key
Nov 05, 2009 | One For All URC-1050 Remote Control
Cant enter codes in Eurovox ex1000 sl
if you need to manually enter the keys a different procedure is required to previous versions of the firmware.
To access the key entry screen try the following:
On the remote press "Menu".
Highlight "Language Settings" and press "OK".
Highlight "1st audio lang" or "2nd audio lang" or "Subtitle lang" NOT "Menu language", then press the buttons 1,9,6,8 in order.
The key entry screen should now be visible.
Use the left/right arrow keys or "FAV" button to find the "NagraVision" screen which contains the keys for UK service providers.
to reveal the "Emulation" and "EMM Capture" Highlight "Menu language"
Aug 21, 2009 | StarTech.com StarView SV211K 2-port KVM...
CODE FOR SHARP TV
I hope that helps.
Jun 27, 2009 | One For All URC-1050 Remote Control
Service code H2-01
Press "#" "Interrupt" "Clear" "Interrupt" then hit "14" "Start" then go to sub code "0" or it may ask to clear code.... Good Luck..
May 13, 2008 | Sharp AR-M237 Digital Copier
Sharp 56DR650 56" Rear Projection HDTV Logo
340 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
