Question about InFocus LP650 Projector Lamp
InFocus LP650 will not come on
We have InFocus LP650 that is about 5 years old. Just assumed that bulb needed replacement, changed bulb but still would not come on. Power light is a steady blue color when plugged into power, pushing the switch button doesn't change it. This color is not listed in manual in troubleshooting section. I contacted InFocus tech support got no information from, they just wanted me to send unit to them with $350 diagnostic fee. I took the bulb and put it in another LP650 (we have 2) and it works fine. Anything else we could try?
    Problem Solver:
  • 11 Answers
Sounds like ballast unit, try avalontc.com
Posted on Aug 06, 2008
  • 26 Answers
That color is not listed because it is either Green or Red. There is no Blue, if you are getting Blue, you have something that is extremely unusual.
Posted on Feb 28, 2008
I have a InFocus IN35 w360, I have no idea how old it is, do you? The bulb had dimmed the other day and now it will not power up, is replacing the bulb the only thing I need to be aware of with this type...
More than 5 years old. After replacing bulb you have to reset the lamp hours as follows. To reset the lamp timer, navigate to the Settings>Service menu and select "Reset Lamp Hours"
Aug 15, 2011 | InFocus IN35 Projector
Annoying hum on the projector
are you sure its not the fan?
I supose its good to clean the fan and the inside ones a year.
dust gets in there.
The fan could be failing.
il get back to you about the humm
Mar 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Infocus LP130, Bulb fires then goes out
there is a problem with the power to the front fan from the main board. there are 3 wires going to the fans: one power, one return, and one signal. if the main board reads no signal from the fan's speed, it'll shut down. check the power going to the fans and the signal. you may need to replace the main board.
Mar 03, 2010 | InFocus Office Equipment & Supplies
I have infocus lp70 model projector. i replaced the bulb and now it won't light. i put back in the old bulb and the light still wont come on...any ideas? You can tell that the projector wants to run and is...
if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 22, 2009 | InFocus LP70+ Multimedia Projector
InFocus 4805 - right 1/3 is fine, middle 1/3 dim, left very dim.
the light tunnel is collapsing and needs replacement. the part itself is relatively inexpensive, but you have to be careful if you want to replace it yourself. it's under the colorwheel, which is delicate. when you remove the top, front, and rear panels, remove the colorwheel (which is between the lens and the lamp) and carefully set it aside. there are 2 screws holding the light tunnel bracket in place. remove them and the bracket. pull out the pieces of the tunnel (little rectangles of mirror) and replace with a new one. reverse the steps to put it back together. by the way, you can get the part from any infocus authorized service center (check the infocus website for the one closest to you). part # 306-0095-01
Oct 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
First try a firmware upgrade. If that doesn't help, it seems it might be a power supply issue since you said the led comes on very light. I repair these power supplies. My ebay id is gtitubro
May 29, 2009 | InFocus LP650 Projector Lamp
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
2 bulbs blown.
To be honest, most people who experience short lamp life on the Infocus X2 is on the genuine infocus lamps. If you read the user opinions here, you'll know what I mean. Me personally think that the X2 lamp filter some how manage to block the vents with dust which results in inefficient cooling in effect reducing the life of the lamp. The best thing to do is vacuum the lamp filters regularly and stick to cheap lamps as the oem ones on the Infocus X2 are also no good. Or better still, just replaace the bulb on it's own from here and save a lot of money.
Jan 26, 2008 | InFocus ScreenPlay 4805 Multimedia...
IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Dec 30, 2007 | InFocus Play Big IN76 Multimedia Projector
InFocus LP650 Projector Lamp Logo
630 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
