Question about Compaq Presario M2000 Notebook
Laptop has lines rolling thru the screen
I replaced my lcd screen with new one but i still have lines rolling thru the screen at the bottom of the screen i can see part of the top of the screen any suggestions on what the issue really is?
Im Chad from Dell and it looks to me that you may need to Flash the BIOS. If that does not work you may need driver for updating the video card of the system. This may be a also a known issue for the system specially if system is running vista. Try also to go to website of Compaq and install the latest driver.
Posted on Feb 16, 2008
Pink lines running across screen
Sounds like your lcd screen is bad and needs to be replaced. Try connecting an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the lines, then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same lines as your lcd screen then your video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 07, 2012 | Computers & Internet
Lines at bottom of screen on asus x83v
Your lcd screen is going bad or your video card inside the computer is bad. To isolate the problem Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok then your video card is good and the lcd screen on your laptop is bad. If the Borrowed monitor displays the same lines as your lcd screen, then your video card inside the computer is bad.
May 29, 2012 | ASUS X83VB-X2 Notebook
Top half of my monitor screen shows at the bottom
Try plugging an external monitor to your laptop and see how it displays on it. It can be any kind of monitor even the old fat crt's as long as it has a vga cable that will connect to your laptops vga port.
If the display does not immediately show up, then you will have to hit the FN (Function key)+(F1 thru F12) to show the image. Press and Hold the FN key then hit the correct F1 thru F12 key. The correct F1 thru F12 key will have either CRT/LCD written on it or it will have a display icon on it.
If the image displays correctly on your external monitor, then you will need to replace your lcd screen.
Mar 25, 2012 | Computers & Internet
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Verticle lines in toshiba p305d vista home 64 bit
Defective LCD Screen. Since its new it should be under warranty. Here is the tech support number for Toshiba:
(800) 457-7777
If your warranty is thru the store you bought it from then you might have to go thru the store so keep that in mind.
Aug 08, 2009 | Toshiba Satellite P105-S6207 Laptop
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Replacement screen for eee 900
A quick search brought this up. Its a buy it now option thru Ebay and you can make an offer to get it cheaper. Not my auction but just found it by doing a search thru google.
http://cgi.ebay.com/NEW-ASUS-EEEPC-900-901-904-LCD-SCREEN-8-9-WSVGA-GLOSSY_W0QQitemZ300305851888QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45eb9fa5f0&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1307|301%3A1|293%3A1|294%3A50
Runs about $70.00 with shipping but you can make an offer an get it possibly for a bit less.
Ben
May 18, 2009 | ASUS Eee PC 900 PC Notebook
Can a cracked notebook screen be replaced?
you don't have to purchase a new laptop/all you have to do is call your computer manufacture and get the LCD replaced.
or else
you can connect a desktop monitor with your laptop if you have a desktop
as its cracked so only thing we can do is either get the LCD replaced or connect a monitor with it to use your system.
Jun 09, 2008 | Dell Latitude D600 Notebook
SCREEN HAS SEVERAL LINES RUNNING THRU IT
its your lcd that needs to be fixed. you probably dropped it or bumped it pretty hard, loosen the connection. hopefully you dont have to replace your lcd.
Jan 21, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Compaq Presario M2000 Notebook Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
