Question about Microsoft Xbox® 360 Core System Console
X box headset
Hi, my son has two new headsets for the x box and he's playing live. Neither set is working and we've already gone into settings to make sure they are right. It shows a circle where the speaker symbol should be.
I guess he was unaware that there is some kind of filter on the mic. It would only go on when he spoke directly into it. I think he might have had it a bit to far away. Also, he didn't know that the circle symbol that appeared until he spoke was the idol symbol. The speaker symbol would come up when he spoke. His cousin helped him out.
Thanks!
Lorid123
Posted on Feb 17, 2008
Why won't my motorola finiti connect to my PS3?
I'm having this problem and need help please for my 12 yeatr old son
Jun 10, 2012 | Motorola Mobility FINITI Headset
Friends hear echo when headset is on in x-box live party chat
I had the same exact problem with a brand new x32 headset. right out of the box it was echoing for my friends. Also, if I muted my mic it would kill the chat volume (ie barely even audible). I switched the voice to play through speakers and it worked flawlessly after that.
Not sure if it is a hardware issue with my controller (my other headset worked just fine) or if it is a defective cable I received, or a design flaw with the x32. If you are looking for a work around, try setting it to play through speaker.
May 15, 2012 | Voyetra Turtle Beach Tbs-2265 Ear Force...
How do i fix echo in the x1 turtle beach
That's probably a bad chat/controller cable. A new chat/controller ("puck") cable should fix it.
Also, make sure you have the Dashboard > Live > Voice settings at "Play Through Headset" not Play Through Both.
Feb 23, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
My turtlebeach has been fine, bur all of a sudden i`t wont output my voice, its not on my i`ve check all the cables and i dont know what to do. Earforce XLC
You have to put your XBL Voice settings on Play Through Speakers or Play Through Both. Try either setting to see if one works better than the other.
Feb 06, 2010 | Voyetra Turtle Beach EarForce XBL Headset
Voyager 520 headset on a macbook, trying to use skype
have you gone into system preferences/sound.input/output settings?
try making a free test call, and you can play around with all your settings that way...also helps to keep the volume turned down on your mac, and just adjust it using your headset.
Jan 05, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My computer can't detect my friend's headset
A lot depends on two things
How they connect, Bluetooth or wired.
The sound card in the computer.
If Bluetooth, it has to be paired. If wired it has to be in the correct socket and they are seldom marked.
Some sound cards are not Duplex, in other words they can only listen or transmit, not both. There are also Sound Mixer controls in Settings, and one of them is a box that has a check mark for MUTE. You can usually get to these settings from the icons down in the Systray by the clock.
Nov 24, 2017 | Logitech 250 Headset
Headset sign
(Plz.read fully)
Hai friends,let me first inform u that how your nokia 6630 detects it's headset.
There are 13 connector pins at the boottom of yr cellphone.4 for usb connectivity,others for headset,mic,switch,antenna(not in order).
The first pin from left(plz. neglect the isolated pin near to the edge) is ground
(-ve) and the second one act as a sensor for detecting headset is connected.
When the normal headset jack is plugged in, it short circuits the ground pin
Aug 12, 2008 | Nokia 6630 Cellular Phone
Can't get my headset to work with Xbox 360!!!
When i got my headset i got the same problim...btw u cant hear your own music through headphones anyway....go to system settings....family settings....xbox live controlls....enter email and pass.....privacy and friends....voice and text and make sure its set to everyone. If this does not work i suggest you search system settings from back to frost untill u get them working....also in some games u need to press a button to speak look at your game manual to find out if you have to do this.
Feb 06, 2008 | Logitech (980174) Headset
X box 360
Make sure the headset connector and the headset jack on your controller are free from dirt and debris, which may interfere with sound transmission. More importantly, ask your fellow gamers and conversants to check their connectors, as the poor sound you hear may well originate from someone else's headset. 1. Examine and then clean the Xbox hardware. To do this, follow these steps:a. Examine the headset, the cord, and the connector for visible defects. b. Make sure that there is no dirt or debris on the Xbox 360 Headset connector. ? To clean the connector, use a cotton swab dipped in rubbing alcohol. c. Verify that the Xbox 360 Controller operates correctly. ? Verify that you can use the controller to turn the console on and off. d. Firmly insert the Xbox 360 Headset connector in the expansion port under the directional pad (D-pad) and the right stick on the controller. e. If this does not resolve the issue, go to step 2. 2. Test the headset. To do this, record and then listen to a new voice message. To record and then listen to a new voice message, follow these steps:a. Press the Xbox Guide button on the Xbox 360 Controller. b. Select Messages, and then press the A button. c. Select Create New, and then press the A button. d. Select Message, and then press the A button. e. Select a gamertag, and then press the A button. f. Select Add Voice, and then press the A button. g. Put on the Xbox 360 Headset. h. Select Record Message, and then press the A button to start recording a message. i. Speak clearly into the microphone and record your voice for 5 to 15 seconds. j. Press the A button to stop recording. k. Select Play Message, and then press the A button. l. Listen to your recording. ? If you can hear the recorded message, your headset is operating correctly. If the headset still does not function correctly when you use the headset on Xbox Live, you may have to configure Family Settings. Go to step 3. ? If you cannot hear the recorded message, your microphone may be muted, or the earpiece volume may set too low. Verify that the controls are adjusted correctly. 3. Configure Family Settings. Note If you set up a profile for a child on the console, Family Settings lets the owner of the parent profile control who can communicate with the child profile on Xbox Live. In Family Settings, you can enable communication in the child's profile. The default setting for gamers who are under 17 is Friends Only. To configure Family Settings, follow these steps:a. In the Xbox Dashboard, select System, and then press the A button. b. Select Family Settings, and then press the A button. c. Select Xbox Live Controls, and then press the A button. d. Select the child?s profile, and then enter the password of the parent?s profile that is associated with the child's profile. e. Select Privacy and Friends, and then press the A button. f. Select Communications, and then press the A button. g. Select one of the following options: ? Everyone This setting lets you communicate with anyone on Xbox Live. ? Friends Only This setting lets you communicate with people who are on your friends list only. ? Blocked This setting blocks all communication with the headset. Note With this setting, you can still receive new friend requests. h. After you select the option that you want, press the B button until you return to the System section.
Sep 20, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox® 360 Core System Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
