Question about Nokia 6215i Cellular Phone
My phone won't ring
On my phone profile it states it is active but my phone won't ring.
Help!
My phone won't ring and i've tried everything! Its in good shape and it hasn't gotten wet at all!
  • twistedwhisk Oct 01, 2008
    My phone won't ring , but it will vibrate and it the speaker phone won't work. I've tried everything , changing randomn settings, etc. But nothing seems to work.
    Thanks!
  • Anonymous Mar 05, 2009
    same problem. won't ring but will vibrate. Also there is no speaker but i can hear key tones.
    Problem Solver:
  • 8 Answers
>>> if u already fell down of u r mobile means please try to change the ringer
>>> otherwise try by the softwares...
Posted on Feb 16, 2008
When i ring someone or they ring me they having suddenly become very quiet and hard to hear but my ringtone and message tone are still at the same volume, i've adjusted the volume level to highest and...
Hi here are some solutions hope it can be helpful..Go to the setting on the menu.make sure that what profile setting specifically the volume the ringtone either text or call that was personalized was the one that was activated..
Jun 19, 2011 | Nokia C3 Cell Phone
Tip
Phone is not ringing
Please try the following troubleshooting tips:
  • Ensure that you phone is on and that there is sufficient signal strength.
    • Signal strength is indicated by the signal indicators at the left side of the phone's display,
    • These indicators move up as the strength of the signal increases and down as the signal decreases.
    • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
on Sep 13, 2010 | Cell Phones
Ibought my nokia e63 a week ago. Now there is no sound when it rings and no vibration i did go to the settings and set everything the way its supposed to be. I did not let it fall or anything. I put my...
u can try this
go to profiles then select the profile u want to activate then go to its customize menu and incoming call alert type and select it ringing
Aug 23, 2010 | Nokia E63 Cell Phone
How can i activate my ringtone
hi....
please follow these steps to activate you ring tone.
1.open menu--->profile---->select the profile which you are using currently
2.After selecting the profile---->select personalise from it.
3.there is an option in it,Incoming call alert
4.In that you have to select ringing to activate the ring tone.
5.There is an option called as Ringing tone,you can select which ever ring tone you want and save the changes.
thanx
Jul 18, 2010 | Nokia N73 Cellular Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
Nokia 6300 has stopped ringing anyone any ideas?
o.k. does it vibrate?
have you dropped it?
You may have accidentally put it on silent mode:
HERE IS HOW TO CHECK YOUR TONES OR PROFILE:
10. Settings
Profiles
Your phone has various setting groups called profiles, which you can customize with
ringing tones for different events and environments.
Select Menu > Settings > Profiles, the desired profile, and from the following
options:
● Activate — to activate the selected profile
● Personalise — to change the profile settings
● Timed — to set the profile to be active until an end time. When the time set for the
profile expires, the previous profile that was not timed becomes active.
Themes
A theme contains elements for personalizing your phone.
Select Menu > Settings > Themes and from the following options:
● Select theme — Open the Themes folder, and select a theme.
● Theme downloads — Open a list of links to download more themes.
Tones
You can change the tone settings of the selected active profile.
Select Menu > Settings > Tones. You can find the same settings in the Profiles menu.
If you select the highest ringing
all this can be found in your manual:
here is a link to the manual for: nokia 6300
please remember to rate my help if it was of assistance it helps me too.
Mar 26, 2010 | Nokia 6300 Cellular Phone
NO sound nor vibrate with email
Check your sctive profile and the settings for each of these options - It may that you have changed one of your profile settings which is no longer active.
From the home screen - Go to profile, scroll to the bottom for advanced, your active profile will be highlighted, choose edit.
May 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
My phone is not ringing
You have either turned off your ringing by choosing the quiet profile or you have changed the settings for your defaul profile. Either way what you can do is go to menu and choose profiles. You will have an Active sign by your profile. If you have the quiet profile as Active than you should change it to Normal.
If you click on advanced in the profiles section you can change the audi settings for your active profile.
best regards
Mar 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
BlackBerry Storm 9530 will not ring
It seems like the problems starts after using an audio streaming app (Slacker)It also seems to correct after a reset(battery out and back in).
Feb 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
My phone won't ring
Do you have an icon on the phone similar to the one that you see when your phone is in silent mode? A striked out music note code? If it is there check the incoming call alert in your profile personalization setting, it should be ringing or ascending.
Jan 24, 2008 | Nokia 6300 Cellular Phone
Nokia 6215i Cellular Phone Logo
98 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
