Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Sony KF50WE610 Lamp problem
The TV turns on, and works fine so you can see/hear/ the TV, but after about 5 minutes on, the sound and screen turn themselves off for about 60 seconds, and the cycle starts over again.
Any help About how this can be fixed???
Thanks
Replace lamp
Posted on Mar 04, 2008
What is wrong with my sony kf50we610?
Chances are the lamp needs to be replaced.
May 20, 2013 | Sony Grand WEGA KF50WE610 50" Rear...
Just replaced the bulb .it is working fine for couple of days..now it won't turn on,the lights just blink and turn off by itself
take out bulb and put in freezer for 5 minutes. then when unit comes on, go into menu and select lamp setting. it will ask have you replaced bulb? select yes and lamp timer will reset to zero hours
Oct 30, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Our Sony 50" LCD Proj TV turns on and off every 2 minutes or so.
If you have never changed the lamp that's probably the cause.If it has been replaced already suspect the lamp driver(ballast)
Aug 25, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Wega KF50WE610
5 red blinks = lamp driver or ballast failure.
we610 part # = 1-468-798-14
replacement is straightforward when you unplug the set and open the back up. remove the metal support bracket to expose the ballast. make sure to keep all wires routed as you found them.
Nov 22, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv turns off then on
It's time for a new lamp. What you are seeing is the result of a weak or old lamp and the TV sensing that it is drawing too much power and turning it off. I've seen this many times; a new lamp will cure. Be sure to buy an original Sony lamp as the aftermarket replacements are known to have problems. Please be sure to rate this solution. Thanks!
Nov 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand Wega KF50WE610 Video/Audio disappears every 1-2mins
Hello apharcha,
99.99% its the lamp. You may also have a faulty door, but thats kinda just 2% possibility. Change the lamp...its due anyway.
List Price $200.00
Part Number A-1606-034-B Description LAMP BLOCK XL2100U
Best regards
circuitcity
Jun 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
TV Goes Blank after 5 minutes
If the lamp indicator stays red then you do need to replace the lamp if not without a service manual for your tv its difficult to trouble shoot the problem but if you don't have one you can get one at this sight along with free online tech support
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Hello EUPHOR1C,
Your only problem is a Bad lamp. You must change your lamp in order to fix this unit. Lamp Part number: A-1606-034-B
Average cost under $200
Best regards
Circuitcity
Dec 16, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
145 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
