Question about Jenn-Air JGW8130A Electric Single Oven
Oven door lock engaged while NOT in cleaning mode with door open. Will not disengage. Cycled main power, cancel button does not work; Oven also inoperable. HELP! Appreciate any tips or tricks to get it unlocked. Thanks. I hit the oven clean button by mistake thinking it was broil. At that time the oven was heated to 350 degrees. The oven door locked with a casserole in the oven. Then I pressed the clear/off button many times. The door locked button became unlit. I pressed the clear/off button for longer as that works with my breadmachine. I waited overnight for the oven to cool completely and tried various button combinations again. No luck. I switched off the breaker switch and left it for over 5 minutes twice. Any suggestions?
  • 5 more comments
  • JeffShadbolt Feb 26, 2008
  • Anonymous May 11, 2008
    Door locked while something in oven. Model number 362.7585590
    how do you unlock it?
  • Anonymous Jun 20, 2008
    my oven door is locked, nothing works.. how can i unlocked it?
  • Anonymous Sep 07, 2008
    i have the same problem and no buttons work and the lock is on and got an F-44 code one time thank you
    door locked is on and wont do nothing and at one time it gave a code F-44 and buttons do nothing
  • cake1cj Sep 29, 2008
  • eckmans Dec 18, 2008
    appl_doctor:
    I have the same problem with my GE JTP85. went through self clean and now the door wont unlock even after completing cooling and cutting power. Can you help?
    Scott in Roseville
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Posted on Apr 01, 2009
Solution can be taken roughly but tis worked for me. unplug it then wait. the system will reset and unlock the door. i just had the same problem and maybe i was just lucky, but that is the only thing i did. alternatively, flipping the breaker should do the same thing. either way leave it off for a while - ten minutes plus or the amount of time it takes to clean behind there - then plug it in an wait some more until trying the lock again.
Posted on Jan 18, 2009
Me and my mom just had this same problem. i dont know if it was my chance that i fixed it or this is actually how to do it .. all we did was retsart the self clean. pressed start than stoped it right away the lock light was on. a few seconds later it unlocked itself.
Posted on Dec 20, 2008
    Sniper:
  • 65 Answers
Need model number and ill tell you how to open mod number prob at pull out drawer
Posted on Feb 16, 2008
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
Lock won't disengage
Try putting it into CLEAN MODE and wait about 3 minutes.... then cancel the clean mode. Sometimes this will release the relay if its stuck.
If that doesn't work, you have a problem with the latch relay and you need service on the unit. You can try and remove the latch assembly yourself, but it can be tricky, and you may create more problems than you fix.
Jul 19, 2008 | Ovens
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Jenn-Air JGW8130A Electric Single Oven Logo
405 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
