Question about Zenith Z25X22S 25" TV
Programming high number cable channels
I can not program high number cable channels on the television? Help
  • 77 Answers
On your remote there is a menu button press that and do a channel search it should fix the problem
Posted on Feb 16, 2008
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Sony Trinitron KV-27TW77 will not change channels after setting up auto program. Remote or TV will not change channels.
You have not cleared the number of programs tuned in the auto mode,if only one program is tuned than only remote or TV will will not change channels,check by tuning with cable connection with multiple programs,you will get the solution.
Feb 06, 2011 | Sony Televison & Video
I'm trying to set up the TV channels for the View Sonic 2750. I'm unable to program channels 3 & 4 to allow the cable converter box to work. The cable channels start at 181 and stop at 90 the air...
try using the number keys on control an manually program numbers in that way, if you select auto tune, it will only try to program any channel it gets signal for, once you type the numbers in that way, it should ask you to save that channel number, in which of course you select yes... try that, also refer to owner manual or mfg website.
Oct 17, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Hello! I'm trying to program cable but it's not connecting. The skip channel keep coming on.
If you are on Comcast cable there are very few stations that will program on your analog tuner. I believe it goes as high as channel 34. Past that you need to get a DTA or digital television adapter from Comcast. You get a total of 2 for free.
Aug 28, 2010 | Disney 13" TV
Cannot program all cable channels into tv.
is it keeping low channels or high channels because you have diffrent tuner bands may be eeprom also
Apr 03, 2009 | Televison & Video
Cable problems
Go into your Menu under Tuner, make sure Cable is checked or high lighted, then proceed to Auto Program.
Feb 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Channels stops at 15
Do you have the antenna set to cable? Also some of the channels may be not added. Try to manually add each channel see if your able to do that.
Mar 29, 2008 | Televison & Video
Sharp tv/vcr combo
go to menu go channel auto search
Dec 13, 2007 | Sharp 13VT-N100 Combo
I need to program my tv is cable ready
plse help, i have a cable ready tv hooked up to the coax out of the wall directly to tv and only get 1-13 channels??????
Sep 11, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
