Question about SanDisk Sansa Clip MP3 Player
Sansa media player
Cannot find a caradapter to charge sansa media player. is there one made for this player?
    Master:
    Sergeant:
  • 462 Answers
Surely it is there, u need to search more in electronics shops, If not i can make one for u...!!! Provided u let me know...!!!
Pass me a good rating buddy..!!!
Thankyou
Posted on Feb 16, 2008
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Sansa not charging
Try plugging in the sansa before you turn on your computer. Push the on button of the computer, then immedietly push the on button of the sansa.
Jun 11, 2009 | SanDisk Sansa E280 MP3 Player
How come i cant sync my music onto my sansa e250 when i plug it into my new laptop but it does charge?
connect your sansa open mediA plAyer click on tools options devices double click on your sAnsA put A check next to start sync etc... click okAy i hope that works with windows media plAyer.....
May 31, 2009 | SanDisk Sansa e250 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Charging
I was having the same problem. In fact, I had exchanged my sansa for a second one and my problem was that my windows media player was a 9 version and when I upgraded to an 11 version all the sudden my sansa player was charging for more than a min. and it seems to be working ok. I think that once I upgraded my media player the computer recogonized the USB and with the older version it did not recogonize it. I don't know why. I just got my new player today and it's still charging so I don't know what it will do once it's fully charged but at least I can get it to charge for more than a min. I will keep you posted.
Nov 05, 2008 | SanDisk Sansa Fuze MP3 Player
Battery doesn't charge properly
The solution for this problem was upgrading my media player that had a sync funcition on it. hope this helps someone.
Aug 23, 2008 | SanDisk Sansa e250 MP3 Player
Sansa clip
Assuming charge is from computer or laptop, you need the following programs: Windows XP Service Pack 2 & Windows Media Player 10 or 11. Good luck!
May 07, 2008 | SanDisk Sansa Clip MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
