Question about Sony RDR-GX300 DVD Recorder
Disc Error Message
I am suddenly experiencing a problem with my machine. It refuses to acknowledge +/- RW discs, whether blank or recorded. It just makes a strange noise like tick tick, like it is struggling, then flashes a Disc Error message after two minutes. Strangely, it will take R discs and those that are pre-recorded. Any thoughts? I am at my wits end on this matter.
FxGentleman
  • 21 Answers
THESE UNITS HAVE SOFTWARE ISSUES. THE ONLY WAY TO HAVE IT FIXED, IF "IT IS THE SOFTWARE" IS TO HAVE IT SENT TO SONY FOR SOFTWARE UPGRADE. THE UNITS USE UNIX AND THE CODE IS NOT OPEN.
PER TO WHAT SONY SAYS YOU NEED TO.
Please send the unit to Sony Service Center for upgrade.
1001 Technology Drive ( PCSC)
Attn: Materials/Door 27H
Mt Pleasant PA 15666
Or
Sony Electronics (LCSC)
10227 crossroad loop, suite C
Laredo, TX-78045
DON..
Posted on Feb 16, 2008
I just purchased new blank Maxell dvd-rw 4.7gb/2hrs. discs and they wouldn't initilize past 8% so I tried re-formatting the disc and now the machine won't recoginize the disc or any disc, even...
Get a CD/DVD laser lens cleaner - the kind with optical quality brushes sticking out of the bottom of the disk. Run this in the player/recorder a couple times. Should clear it up.
You can get them at Best Buy, Radio Shack, online, etc...
Jun 16, 2011 | Emerson EWR20V4 DVD Recorder/VCR
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
Mar 28, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
Mar 13, 2009 | Pioneer PD-R509 CD Recorder
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Sony RDR-GX300 DVD Recorder Logo
288 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
