Question about Canon CLC 1120 Color Copier
CANON CLC 1100
I HAVE ERROR CODE E073 & SUB CODE 0003
CAN YOU HELP ME WITH THIS
This error:
E005
200
Posted on Mar 25, 2008
  • 86 Answers
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Posted on Feb 19, 2008
I installed new toner and drums in a brand new canon IR Advanced c5035 printer and after turning back on i get this error E000075-0003
Title : E075 - 0003
Problem : The machine displayed an error code of E075 with a sub code of 0003. This indicates an error in full displacement of the ITB to the rear side.
Solution : Behind the ITB motor there is a silver bracket with two silver screws. This bracket affects the tracking of the belt. Remove the ITB motor. Loosen the two screws on the bracket and adjust the bracket 1mm at a time until the belt stops tracking off. The location of the bracket and the screws are shown below.
Canon USA, Inc. Engineering Services & Solutions Division
Jun 20, 2017 | Canon Office Equipment & Supplies
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
E073 0003
hello have a look in side the unit to see if you have any paper no mater how small stuck at the back of the transfer unit,and the transfer drum,if not try cleaning the connections on the back of the transfer unit.also check for a broken switch.
maybe just a good clean may do the trick.
hope this helps
Nov 14, 2012 | Canon CLC 1180 Copier
What does e073 0003 error mean on canon 1180
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck.
Courtesy of
andzulisv.
-David.
Nov 03, 2010 | Canon CLC 1180 Copier
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E540
E542
E744
0002
0003
0004
Jul 16, 2010 | Canon Office Equipment & Supplies
Canon clc 1180 error code 073-0003
Dec 28, 2008 | Canon CLC 1150 Color Copier
Error E073-0004
You need to call a copier technician, first and foremost.
This error code indicates that there is a problem with the transfer drawer connector inside of your copier. You've probably blown a fuse, like the FU903 on the DC fuse board.
There is nothing you can do if you aren't a copier technician. Call one right away; the technician can probably fix this in about ten minutes.
Dec 05, 2007 | Canon CLC 1000 Color Copier
E073-0004
Answered elsewhere, but answering here too:
Canon CLC 1120 Color Copier Logo
305 people viewed this question
old marine
old marine
