Question about Panasonic SC-PM91D System
Power on but screens says wait....
I just moved the system from upstairs to down and now when I turn it on the screen says "TRAY INIT" and then goes to "Wait" and none of the buttons work, completely disabled? I read the manuel that says it could be prohibited because of a disk...any suggestions?
  • byersgreen Jan 18, 2009
    The screen say Tray Init and "Wait" Nothing Happens
furion187
  • 54 Answers
SOURCE: dvd tray will not open
Sounds like it's jammed it self up, if you got finger nails try pulling the front on the dvd drive as you push the open button, otherwise look for a little tool of some sort to wedge in the front of the dvd drive to give it alittle movement as you press the open button, it may need a bit, just be careful not to break it lol , if still no luck unscrew the sides and back if it has screws at the back , lift the top off , and push the dvd drive from in there , that will atleast get the disk out, and lets hope solve future problems ,
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
  • 4 Answers
SOURCE: Panasonic SC-HT670
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Posted on Apr 14, 2008
  • 4 Answers
SOURCE: init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
  • 208 Answers
SOURCE: Tray won't open!
Hi, not being too familiar with this model ( i.e. whether a single disc or 5 disc changer). it sounds like the CD player section is trying to find home position and will not continue until it has done so. It is very likely that there is a disc in the mechanism and depending how competent you are with a screwdriver, you may be able to release the disc either by removing the top cover or check on the underside of the machineto see if there is a hole in the bottom where you can wind the cd mechanism to the eject position.
Posted on Feb 07, 2009
How to remove password from printer hp laserjet m4345 mfp
Turn the power off.
-Press AND hold the down arrow (or left arrow) and cancel at the same time.
-Turn on printer still holding the keys.
-Wait until message "Permanent Storage Init"
shows on screen.
Aug 03, 2017 | HP Office Equipment & Supplies
Forgot password
  • Turn off the unit.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Nov 15, 2013 | Coby Kyros 716829701508 Tablet PC
How Do I Get Past a Pattern Lock MID8024
  • Plug the unit into an electrical outlet.
Aug 23, 2012 | Coby Kyros MID80244G Tablet
Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
Try a master reset:
Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
I am having problems with my SA-HT670 it is reading error code INIT and then WAIT. The 5 disc changer will no open and close properly
The CD loading mechanism is not resetting properly. When powered on, the entire mechanism goes through a startup alignment sequence. This is to be sure that the unit is in a known position and state. The init indication is for the "electonics" reset portion, the wait message should be present while you hear the mechanism move. The most common cause of this is a slipping belt or a jammed CD. Be cautious about trying to repair this yourself. It is easy to damage the gearing inside or to get it out of aligment. There is a good possibility that this can be repaired with either no parts or with a $3-$5 belt.
Dan
Nov 02, 2010 | Panasonic SC-HT670 System
My power save came on, which turned my laoptop screen off, i moved the mouse, the system started up again but the screen remains black/very dark . the only way i can see my computer screen is if i connect...
It sounds like a driver recovery issue, you may have to do a hard reboot. Hold the power button in for atleast 10 seconds or until your laptop shuts down completely, wait 30 seconds then turn it back on. If this fixes the problem you need to upgrade your video driver and/or your Operating System.
Mar 24, 2010 | Computers & Internet
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Unit says Init Please Wait
Oct 31, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670
Sep 24, 2007 | Panasonic SC-HT670 System
Panasonic SC-PM91D System Logo
245 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
