Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Will not spin
My machine is now about five weeks into washing day frustration. This baby has a mind of his own. Sometimes it will spin, sometimes it won't. After sloshing around for 23 minutes trying to get up the gumption to actually go into the spin mode, the machine stops, you hear the door lock click open, and the display says to remove clothes. Sopping wet. Not overloaded or big bulky items, just normal everyday laundry. So the only way to get it to spin is to push refresh, then the machine rinses AGAIN, and maybe, just maybe it will spin. I am ready to take the washer and dryer back to the store and go for a different brand. Any comment Bosch?
And yes, the bolts are off, the display is set right; the machine spins when it's good and ready, and 15 to 20% of the time it just refuses to spin. It is freezing cold here in Michigan, and I have nightmare visions of myself hanging up clothes on the clothes line just like Mom used to do back in the 50's, and hours later bringing in frozen slabs of laundry. Ahhhh, progress!!!
  • 3 more comments
  • little Addie Feb 18, 2008
    Thanks so much for the advise! The solutions could be helpfull ahhhh, if only the drain hose was blocked, or the drain pipe blocked. Alas, no blockage. The machine will work okay one load, and not the next. I am now searching out online a different brand if Lowe's will be so kind as to take this lemon back. Last washer lasted 35 years and one week. New washer, just one week! Will keep you posted on the outcome of "lemon" washer and the new replacement.
    My daughter has a front load Maytag and just loves it. Hey, it even SPINS! What a novelty.
  • twiigg Mar 29, 2008
    Receiving error code E13 from our Bosch Nexxt DLX model # WFMC4301UC washing machine as well. Washer works normally up until rinse cycle, then starts beeping, displays E13 and will not complete the cycle. We have to turn the washer off, then manually select rinse and spin cycle... sometimes this works, sometimes we have to repeat the steps again to complete the cycle. VERY DISGUSTED!!! As much as this washer costs, expected more than 11 months of service without problems. Guess we'll call the repairman as no one seems to know what the error code means.
  • bosch12wen May 03, 2008
    I load half the clothes of my old Maytag which I could wash 6 beachtowels. The same dripping problem is ridiculous for even a few clothes and the machine smells after 2 months.
  • Anonymous Feb 28, 2009
    Sometimes the washer will not spin to get the cloth dry, sometimes it will fill up with water, halfway up the drum.
    What is up with that, it is a new maschine. It is a Bosch nexxt 500
  • fdcardwell Mar 20, 2009
    Frequently does not go into the spin cycle (seems random). Clothes come out sopping wet. Also, frequently takes forever to complete a wash...says 1 minute left and 20 or 30 minutes later its still running. Unit is only a few months old.
    New Friend:
I too was having this problem I relize this has been a while since the last post...... When I took off the three way rubber boot thing there was no Ball in there..... does any one know the part number or if Im looking in the right place?
Posted on Jan 11, 2013
There is a 3 way ball valve assembly between the drum and the sewage pump. It looks like a 4 inch diameter rubber elbow. You can access it by opening the back of the machine (unplug and completely drain first!)
If you remove the clamp that holds the assembly to the drum and look inside, you see a white ball. Make sure nothing blocks this ball from pressing up against the rubber ring that holds it in place. In my case, I just found a toothpick in there.
The third " - much smaller - exit from that 3 way assembly goes into a small rubber hose connected to a switch in the upper part of the machine. That's a pressure switch. If the ball doesn't close because something is stuck in there, the pressure switch doesn't work and the machine will stop draining. The electrics in there are smart enough to notice that the draining cycle never completed, so it won't spin.
Disclaimer: I'm not an expert (though I do hold a german engineering degree). So do this on your own risk. It's simple if you're handy and takes only about half an hour to drain, disconnect, pull out, open machine, pull off the valve assembly, clean and put it back together. Mine is happily draining and spinning now.
Posted on Dec 18, 2009
Spoke with a friend who happens to be a Bosch engineer. He told us to check out the inlet of the pump (behind the round access port on the lower right side of the machine)- The problem turned out to be one of our 2 year old's socks jammed in the inlet of the pump that drains the washer. Lesson learned... use a garment bag for small items to prevent this problem. Guess I have to retract my comment about the quality of the washer... it was our fault.
Posted on Apr 02, 2008
  • 236 Answers
Sounds like a pumping problem, if the drain hoses/filter are not blocked then it could be a faulty pump.
Posted on Feb 16, 2008
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Jul 27, 2012 | Hoover Washing Machines
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Beko wma510w only spins when it feels like it
I have the same model and problem. I suspect the problem is due to the machines sensor which detects when it is off balance. The problem is most likely to occur when doing something like a single large towel. You can see it thinking about spinning but as soon as the drum starts to wobble it slows back down again.
Any ideas on how to stop this happening (sensor replacement) would be useful.
Jun 21, 2009 | Washing Machines
Odd messages appearing on lcd screen and not collecting water
What make and model is your washer?
Cannot help without further details
Nov 19, 2008 | Hotpoint Washing Machines
Kenmore Elite Washing Machine with Calypso Wash Motion Model # 110.22066102
have you removed bottom panel and cleaned pump..old style pump was held om with clips but the splined shaft in the pump would strip out and never pump properly only solution was replace pump/motor style pump had 4 screws in bottom and could be removed and cleaned
Aug 21, 2008 | Washing Machines
Top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Mar 08, 2008 | Washing Machines
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Rumbling noise
Most likely the rear bearing is bad. It would most likely not be cost effective to repair.
Dec 01, 2007 | Frigidaire FTF530FS Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
598 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
