Get dryer to work, no instruction manual for Indesit Washer WDG 1195 W
Cannot get dryer to work.
Have no instruction manual
    Novelist:
  • 123 Answers
What to check when your dryer won't start-
The wall outlet 240 volts:
The first thing to check when your Whirlpool dryer is not starting is the wall outlet to make sure that the dryer is getting the proper voltages. On an electric dryer there should be 240 and 120 volts present at the terminal block.
A blown fuse or tripped circuit breaker are one of the major causes why the dryer won't start. To check the voltage on an electric dryer you will need to use a multimeter.
The wall outlet 120 volts:
A gas dryer connects to a 120 volts wall outlet, and it is very easy to check the outlet. Disconnect the dryer and connect a hair blower or any other small appliance on the outlet.
If they work, then the problem must be on the dryer. If the don't work, check for a blown fuse or tripped circuit breaker. If the problem is bigger than that, have a license electrician check the house wiring. A bad wall outlet could be the reason why your Whirlpool dryer is not starting.
The thermal fuse:
The thermal fuse is use on an electric dryer as a safety devise to open the motor circuit if the operating thermostat fails to open at the preset temperature or if the motor draws too much amperage.
A blown thermal fuse could be the reason why your Whirlpool dryer is not starting. It is located behind the back panel on the dryer.
The door switch:
The door switch is another safety device use on the dryer. It is connected on the neutral line of the motor circuit. A door that is not closing properly or a bad door switch could be the reason why your Whirlpool dryer is not starting.
The push to start switch:
The push to start switch is use to start the motor. There are two types of switches. The older type switch is a solenoid operated door switch and the other one is a simple push to start switch.
A bad solenoid operated or regular push to start switch could be the cause why your Whirlpool dryer is not starting.
The timer:
The timer is the distribution center or the brain of the dryer. Inside of the timer is that the electricity gets routed to the different electrical parts in the dryer.
The timer has contact points, and the contact points wear or burn out depending on the amount of use. Contacts burnt inside of the timer, could prevent the dryer motor from starting..
The motor:
Also, the motor could be burnt bad. A motor that smells like rubber burning, makes growling noises, runs for a wile, the won't start until is cool down or a motor that runs fine, but the centrifugal switch is not making the right connections is a bad motor and must be replace.
So...as you could see, there are many parts that could be the reason why your Whirlpool dryer is not starting.
Posted on Feb 16, 2008
  • 1 more comment
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 16, 2008
    1.The terminal block:
    This is a live test to see if the dryer is getting the needed 120/240 volts necessary to work properly. Do not work alone when doing this test, have someone to plug and unplug the dryer from the wall outlet for you, while you check the voltage .
    These are the readings that you should get.
    Between L1 to L2 = 240 volts
    Between L1 to N = 120 volts
    Between L2 to N = 120 volts
    The following tests are going to be done with the dryer disconnected from the wall outlet, unless I tell you to plug it in. So lets keep checking to see why your GE-Hotpoint dryer do not start.
    2. The timer contacts:
    Remove the red wire on terminal B on the timer and take a reading between terminal B and terminal C with brown wire on it. Reading should be 0 ohms
    3. The thermo Hi-Limit right:
    Take a reading between the brown wire on terminal C in the timer and the brown wire on terminal 1 on the start switch. The reading should be 0 ohms.
    When the GE-Hotpoint dryer do not start, check for a blown hi-limit right. make sure that the exhaust hose is not clogged of this hi-limit will blow again in a short time.
    4. The start switch:
    Remove the red wire from contact # 2 on the start switch and take a reading between terminal # 2 and # 1 with the brown wire on it. When you turn the start switch on, the reading should be 0 ohms
    5. The main motor:
    Check between the red wire on terminal 2 on the start switch and yellow/brown wire on the door switch. The reading should be about 2.5 ohms. Burnt motor windings could be why your GE-Hotpoint dryer do not start.
    6. The door safety switch:
    Check between the yellow/brown wire on the door switch and the ground terminal on the cord, with the dryer door closed. The reading should be 0 ohms
    If you get a different reading that the ones that I posted here,
    then you have to assume that the part is bad and it will need to be replace.
    Good Luck
    Was this solution helpful? Show your Appreciation by rating it:
    If the problem you are having is that your gas or electric dryer is not starting, these are the parts you will need to check until you find and correct the problem.
    The wall outlet:
    The right voltage have to be present at the wall outlet for the dryer to be able to start. 240 volts for an electric dryer and 120 volts for a gas dryer.
    The thermal fuses:
    Some dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting.
    The timer contacts:
    The timer is the distribution center in the dryer, the timer will send the right voltage to each of the individual parts in the dryer. Most common problem with the timer, is burnt contacts.
    The motor:
    The motor is in charge of turning the tumbler, turning the blower to circulate hot air inside of the dryer and making sure that the heating element won't come on when the dryer motor is not running. A bad or weak motor could be the reason for your dryer not starting.
    The door switch:
    The door switch is a safety device use to prevent the dryer motor from starting or running when the door in the dryer is open. Burnt contacts or a broken actuator on the switch could be the reason that the dryer is not starting.
    The push to start switch is single pole single throw switch that is use to start the motor. Once the motor starts running the switch is no longer in the motor circuit. A bad push to start switch could be the cause of your dryer not starting.
    The cord:
    Burnt terminals or wires on the terminal block could be the reason for your dryer not starting.
    As you can see, if any one of these parts fails the dryer will not start.
    The wall outlet - The thermal fuses - The timer contacts - The motor-The door switch - The push to start switch - The cord
    Good Luck
    Thor washer/dryer is either the same company or at least has parts. Go to their website and check for a number for support. You'll probably have to leave a message but they call back and the person can tell you what part you need and give you their parts dept or set up a service call...
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
INDESIT WIDXL126 IS IT A WASHER/DRYER IT WAS IN THE HOUSE WHEN I RENTED IT .THANK YOU.
WIDL is! Washer Dryer so I would expect that you have the 'Xtra' version!
Methinks you could do with a manual anyway but unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 26, 2011 | Indesit Washing Machines
I have a indesit wm12x washing machine and i was told it is a dryer but i can not get it to work please help
I have been looking at your machine on internet and found out that the indesit model you have is not the washer dryer version it is a washing machine so has no dryer function. hope this helped.
Sep 19, 2010 | Indesit W 123 Front Load Washer
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Indesit WD12 washer dryer with a leaking door seal
this is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Feb 22, 2009 | Indesit W 123 Front Load Washer
Cannot work out how to use dryer only
In your browser bar, type in --- indesit user manual
Then in the drop down list click on manuals- user guides- hanbooks
In the search box type in your model number, and you will be able to down load the instructions.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Washing Machines
Instructions
Here below instructions for Indesit W123 selected on title. This model has no dryer.
Washing machine
Jan 11, 2009 | Indesit W 123 Front Load Washer
Indesit washer-dryer wd125 manual
I've been looking for these instructions and have just stumbled across them . Just inside the door there should be a barcode. On the top right check the model no. mine is WD 12S, despite the model no on the outside being WD125.
If so, look here http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WD12S.pdf
ATB
The Mighty Lev
Apr 23, 2008 | Washing Machines
Indesit 1200 washer/dryer instructions
probable cause is just poor water flow from outside. switch water off. undo hoses and check not kinked. in each hose, there should be a gauze filter. clean this. look inside the valve spigot and check no dirt buid-up. put hoses in a bucket and check water flow is ok. remove drawer and check holes in top of box are clear
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
205 people viewed this question
Top Washing Machines Experts
