Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No picture no sound.
Model# 9p6034 c102, serial# 33192207, ptv835
I have no picture and no audio. The green led on front works as if everything is ok. it flashes no code and the set makes no sound at all and un plugged for several days to reset its self at no unveil " Its dead". The fuse is good and i have the main board ( attached to the power cable) out right now. I am good with a volt meter and a soldering gun. I am in need of a wiring schematic ( service manual ) and some good advice. This seems like the place to get both. thanks in advance.
  • montee Feb 16, 2008
    only the led blinks on front of the set with the remote or by hand. the screen has no display at all. either on or off (dead). thanks for the manual info, I need help trying to pinpoint the problem.
    there is no display on the screen at all. only the led on front works. unpluging it even after over a month there is no change. the set makes no noise at all after a hard reset.
    this problem has happend before and a friend looked at it said something about a fly by or fly back transformer and used his "magic touch"
    and it worke for the last year.
    Genius:
  • 1,665 Answers
The screen is blank with no raster at all and there are indications that the channel numbers are changing in the display.
This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no HV, you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection. Initially check for bad fuses. For further examination if you are familiar with electronic repairs, you will need service manual to proceed or call an authorized tech service. http://servicemanuals.vstore.ca/product_info.php/pName/9p6034/cName/phillipsmagnavox
Posted on Feb 16, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 16, 2008
    The flyback transformer (FBT) must be removed and have it checked thru a flyback checker from any electronic repair shop. You will be able to confirm whether you have a problem in the high voltage section.
    If (FBT) is OK look for a shortage in the horizontal section specially the horizontal output transistor.
    The area around FBT must be thoroughly cleaned with electromotive cleaner.
    Inspect for cracks, bad solders, burnt resistors, capacitors, diodes, etc and resolder or replace.
    If you can not do the repairs yourself, it is better to take it to a TV repair shop.(Note that this way the cost increases drammaticaly)
    Novelist:
  • 123 Answers
The set has gone into protection overload status.
You must unplug the power cord for 3 or 4 hours and power it up again.
If the hard reset above does not bring it back to life it needs technical service. There are about 10 sections that would need to be checked to see where the overload conditions are causing the problem.
As a general rule this type of failure is severe and expensive. Typical costs of repair are always over $200 and most often closer to $400.
Common failures are main power supply, high voltage supply, deflection amplifiers and so on.
This is not a user or home remedy type repair. If you are lucky it may be something not so costly, but experience tells otherwise.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 16, 2008
    No, you don't need a new lamp. The set has gone into protection and needs serious servicing. Any one of the 10 or 12 sections of the tv when defective can cause the set to go into protection. The analysis of which one and where can only be done by a competent technician. A very common problem with all rca sets is power supply failures and convergence sections. The cost of repair - which is always an advanced job for the most experienced techs - is around $300 to $400 area.
    If you like the set, keep it and get it fixed. If you want to move up to some of the new technology such as Plasma or LCD flat screen stuff now would be an excellent time to do it. The problem with rca sets is once they start failing other failures follow soon thereafter.
    Hope this helps.
    Good Luck
Bauhn 58cm F H DEfinition LED LCD TV with in built DVD Model MD21067
Check its sound settings. If audio is muted, there will be no sound output. If its OK, and not muted, check its speaker/s. If found OK, check and replace damaged component/s at its audio output stage circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 19, 2014 | Televison & Video
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Philips Magnovox Rear Proj. TV wont keep vertical/horizontal hold
Hello clifftonian,
I would suggest checking the HV trippler block and the voltage output from the IHVT (Integrated High Voltage Transformer), and comparing them against the schematic diagram. In addition to this after solving your HV problem I would suggest doing a complete convergence adjustment, both static and dynamic. Just don't go replacing parts because that approach does more harm then good. Troubleshoot the problem and find out what other parts are marginal and replace them all. Your stepdad is correct with a good place to start.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
Put the old chip back in...does the shrinking/expanding problem return? If so the new chip may be faulty.
If the problem stays the same - no audio/video  - check your soldering, cables, etc.
Nov 02, 2008 | Televison & Video
Creative cambridge sound work megaworks thx 5.1 550
i lost my Creative cambridge sound work megaworks thx 5.1 550 cable.can i use any other cable?
Jun 22, 2008 | Creative Labs MegaWorks THX 550 Computer...
Philips - Magnavox Model # 9P6034 C103 Picture problems? Please Help
1 5 oz bottle should be enough for each tube. The small picture is caused by bad opto-couplers on the large signal board. Let me know if you need more info on the couplers and where to get them
May 15, 2008 | Televison & Video
No screen, no sound, only the green light at the front of the set on.
There is alot of things that would cause this -shorted hori out put leaky or bad capacitor,you are looking at repair cost anywhere from 250.00 and up.also this set is famous for bad convergence broad & weak tubes!
Jan 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 9p6031c no pic. no sound just green light on!!!!!!!!!!!
IC Chip went out. Check www.magnavoxhelp.com for a repair kit
Nov 18, 2006 | Philips 9P6031C 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
