Question about Dishwashers
Dishwasher We are having a problem with our Whirlpool ADP5540 dishwasher. We have just moved into a new house with this model dishwasher and have tried running it on a number of cycles. It always seems to stop part way through and the start button then flashes three times. Any ideas what the problem is or how to fix it?
  • 1 more comment
  • Kelsco Feb 16, 2008
    Thanks for getting back to us, This model dishwasher only has a control knob for setting the wash cycles, no buttons. Do you know if there is still a reset option for the control knob models? It also appears that there is nothing inside the lower door panel to help us out either.
    Thanks again. It turns out that we've been resetting it without realising. We've been holding the start button in until it stops flashing and then trying again. Unfortunately it does exactly the same thing on the next cycle so it seems that a simple resetting doesn't fix the problem.
    We appreciate your help, hopefully you are able to find something on the fault index.
  • Kelsco Feb 18, 2008
    Sorry... they do give a more detailed model number on the side of the door. It is 6 ADP 5540 WH. Thanks
  • 5,911 Answers
If this is a blinking "clean light", this is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there are some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
Posted on Feb 16, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 16, 2008
    Sorry...I didn't diagnose it correctly the first time. I thought this was going to be an easy one. I'm still looking for the fault index for your model dishwasher. I was able to find out that you can reset it by holding the start button in until the light goes out. Try this a let me know if your problem went away. In the mean time, I'm still looking...
  • Jeff Rockwell
    Jeff Rockwell Feb 18, 2008
    Could you please provide me with an EXACT model number for your dishwasher? The information should be located on a tag located on either the left or right hand side of the tub opening with the door open. I'm still searching for the information you requested, but I'm just not having any luck with the model number "ADP 5540". Double check and post back please.
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
I have just moved into a new house with what looks like quite an old ADG7540 dishwasher. The detergent dispenser doesn't open during the cycle - even though I have cleaned it. There also doesn't appear to...
Hi jo..... many of the old dishwashers did not have an upper arm. Regarding the detergent dispenser there are a couple of reasons why it no longer operates but rather than spend money on a repair I recommend that you simply purchase the 3 in 1 tablets and toss one right into the floor of the dishwasher and turn it on. That said, always run the hot tap water into the kitchen sink until it is as hot as it will get BEFORE turning on your dishwasher.
AND since this is an older model always rinse any food or debris from the dishes before placing them into the machine. Joe
Thanks for choosing Fixya!
Dec 04, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool Front Loader drain pump keeps running all drain positions in cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello eastax
Welcome
My advice now a days is :
It's really not advisable to fix a dishwasher that old.
It's putting good money into bad!
Here is an article I just read that you may find interesting.
Repair or replace?
When to pull the plug on your dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems in the owner's manual and on the Web sites of many manufacturers.
Should you pay for a repair or buy a new model? The answer depends mostly on the age of your dishwasher, how much you bought it for, and the cost of the repair. Follow these guidelines from our in-house experts:
When a repair makes sense. If your dishwasher is under warranty or less than four years old , paying for a repair makes sense. Note that dishwasher under warranty might require service from a factory-authorized technician; readers have found them on a par with independent repairers.
When a repair might be a wise choice. If your dishwasher is out of warranty and is four to seven years old, it might make sense to pay for a repair. Readers paid $100 to $200 for a repair. But you might want to buy a new model even at this stage, given that today's models are quieter and have added features. They pay for them selves in only a few years due to higher energy efficiency which is another plus: Energy Star-qualified models made after April 28, 2008, are 43 percent more efficient than conventional models built before 2001 and 56 percent more efficient than those built before 1993.
When it pays to replace. The repair costs more than half the price of a comparable new dishwasher. Our data also show that it doesn't pay to fix a less-expensive dishwasher six or more years old .
Thanks to better recycling programs, less than 10 percent of a dishwasher you replace is likely to end up in a landfill.
Thank you for using our services to advice you.
Please remember to leave a rating!
Oct 05, 2008 | Whirlpool Dishwashers
Whirlpool(model ADP5540) dishwasher keeps tripping the power when switched on.
There is a short in the machine somewhere. Take a flashlight and look around the wiring and see if you can spot a bare wire touching any of the other metal or the frame.
Jul 16, 2008 | Whirlpool Dishwashers
Philips Whirlpool Integrated Dishwasher
Model numbers that are worn or missing are hard to find. When you go to whirlpool's website you might find your dishwasher there, other wise it might not have them listed because it is obsolete.
One place to look is on the panel below your dishwasher door. In some cases it is stuck there, or somewhere else under the dishwasher.
I have seen them inside of the dishwasher housing (under the cabinet between cabinet and dishwasher.
Very rarely will you find the model numbers inside of the dishwasher doors. However according to Whirlpool, if you open your door, you will find a sticker or a riveted plate on the right hand side of the dishwasher's frame, near the seals.
One thing I suggest however once you have discovered the model number, write it down and put it someplace safe.
Good luck
Apr 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher, whirlpool generation 2000+
not enough info. new house? newly purchased house? new dishwasher? newly installed?
check to see if water line was connected
see if a valve has been inserted in water line and is open
if fools day joke, thanks for my time.
Apr 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
685 people viewed this question
Top Dishwashers Experts
