Question about Husqvarna Designer I
DESIGNER SE breaking needles
We have a DESIGNER SE that keeps breaking needles while doing embroideries. It has been to the repair shop 3 times and works for a very short time and then the needles start breaking again. Also it has had a grinding sound since it was new. Help!
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Sounds like the needle to hook gap needs to be adjusted, i.e. the needle is striking the hook when in the lower position. As the needle becomes dull, it probably bends slightly causing more contact and hence breaking. I would try another dealer if you think that might help., You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
HOW DO I OIL A VIKING DESIGNER SE EMBROIDERY MACHINE, TRYING TO FIX THE PROBLEM OF BIRD NESTING.
bird nesting is from needle thread tension being too loose
increase the tension up
May 02, 2017 | Sewing Machines
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Designer 1 se needles keep breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
Feb 09, 2012 | Husqvarna Designer I
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Viking designer se screen is stuck in welcome screen when turned on. update did not help me! my steps: 1turn on Designer SE le and connect to computer. 2install Designer SE 3D embroidery Software...
I purchased my designer se in 2006, and the frozen screen happened for the first time tonight as I was installing fonts on the machine. I did as suggested...got into update mode and installed the latest update and it worked! Thanks so much. I thought I would have to pay a lot of money to have the problem resolved. I am a happy DSE owner.
Dec 04, 2010 | Husqvarna Designer I
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
I have a Disney Brother SE-27OD Embroidery Sewing Machine When I am doing the embroidery the needle comes out I put it in as tight as possible but it keeps happening from time to time.
Make sure you have the flat part of the needle to the back when putting it in and that it's (preferably) a Schmetz embroidery needle with the red band either 75 or 90 or a Schmetz universal 80. Make sure when you install it you can see the top of the needle in the needle slot and all the way up so it's hitting the post before you turn the screw tight. Check the screw each time you sew to make sure it hasn't shaken loose from embroidering.
Dec 13, 2009 | Brother SE-270D Computerized Sewing...
Hello, I have a problem with the HUSQVARNA DESIGNER SE, in effect, the wire breaks every time when sewing. How do I fix this? thread tension has been tested several times but always the same problem. Thank...
If your thread is breaking while your doing embroidery, there could be a few different reasons. 1. The fabric in the hoop has to be as tight as a drum. When you "flick" it with your finger it should give you a poping type drum like sound. If the fabric can flex while the machine is sewing, you will break thread everytime. Also you need to be using the correct backing on the fabric. Your machine has a embroidery advisor that will aide you in choosing the right style of backing for the type of fabric your sewing.
Turn the machine off for the following:
2. Change your needle to a size 12 universal for most embroidery.
3. Inspect the inside hole of the foot for needle strikes. If the needle has struck the plastic "R" foot, your thread could be getting caught on it.
4.Remove the needle plate and inspect the hole for the same rough edges, there can't be any. Cut a strip of a metal sanding paper the size of the hole and floss the hole if needed to remove the burr. DO NOT ENLARGE THE HOLE. Simply smooth the rough edge. The hole size is critical for proper stitch formation. If the plate is damaged to the point metal is missing from inside the hole, buy a new plate.
5. Remove the bobbin case grey cover and the black bobbin case and inspect the metal round thread hook edge for roughness as well. Smoothing the hook is the same as the plate, you can't change the shape of the metal so don't go crazy sanding it. Just smooth the edge. The thread "races" around this area so smooth metal is a must.
I hope this helps, good luck!
Aug 18, 2009 | Husqvarna Sewing Machines
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
Designer 1: upper thread shredding while embroidering
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Apr 17, 2008 | Husqvarna Designer I
Sewing Machines Logo
270 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
